I have an audio track I want to add to a video. The prints are of the same cut, but the audio has (don't know if there's a term for it) longer instances of silence in between the dialogue/sound effects. Probably something to do with scene changes or the video having less frames. It looks like I might have to edit as I sync, as opposed to just trying to stretch/shrink the audio to suit.
I'm just curious which programs/tools are recommended to accomplish such things? I've synced audio in the past, but it's been a while. So there may be improved ways to do it.
I have experimented with Audacity (deleting the excess silence so the tracks match), but that seems like it could be more time consuming compared to other options, and it lacks the option to view the results as you edit.
Thanks.
This task is one of those where dealing with the problem is either free - or expensive - with nothing in between!
'Free' - you've already mentioned (you can do the same with most audio editors, but it's time consuming).
'Easy and automatic' you can use this: https://www.redgiant.com/products/pluraleyes/ .. but as you can see, it's not cheap.
Maybe one of the other contributors here can suggest something else?.. It would be nice if there is something else like Pluraleyes - but a bit cheaper...Last edited by pippas; 29th Jan 2017 at 07:15.
Syncing an audio track
By carlmart in forum AudioReplies: 10Last Post: 4th Jan 2017, 07:26 -
Need help syncing up audio with video
By TheNeverhood in forum Video ConversionReplies: 11Last Post: 23rd Aug 2016, 07:23 -
Syncing (audio speed change and more)
By Ranching in forum AudioReplies: 11Last Post: 22nd Sep 2015, 21:44 -
Trouble with audio speed and syncing
By Solowing in forum AudioReplies: 15Last Post: 14th Aug 2014, 00:35 -
Video and Audio Syncing
By pboong in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2013, 10:09
