I just started messing around with bluray ripping. And let me get right to the point about blurays in general. They are horrible. I get it. About the noise addition. It is advantageous to the tv's (the ones with the unique filter/image processing features) but otherwise, the temporal noise. The noise that seem to "trail" along the scene, it is horrible. Otherwise, other than that--and the color levels--they are ok. At least you get a larger picture to deal with and with a few more levels of ideas to transfer or archive or whatever your goals are with this medium.
So, i'm trying to test various encoders, using bluray as a hopeful "master" to gauge by. But its not going as well according to plan, per the above comments. But I have no choice and so I will continue searching for and hand selecting those sources to run tests through the encoders I am testing.
Let me give you an example of the disappointment I am facing with, so far:
1. The Fifth Element: heavy noise, but not to serious, but still very noisy. And needed the filter mentioned below.
2. Farscape: not so noisy, but the PAL->NTSC 24fps is not very good. I would say horrible but that is not totally true. There are some scenes where you will see blended frames, and then there are scenes where areas or whole areas are "chunky-looking" for lack of better description of what I see.
3. the color levels are very dark for all of the ones I test ripped so far. If I don't apply any color levels filtering, then in some motion scenes, (in The Fifth Element) the color tends to "starburst" if that's the correct term. Anyway, I found that if I include the ColorMatrix(mode="Rec.709->Rec.601") filter, (see script below) then that artifact goes away completely. And, but If I apply a levels filter (to bring levels within 16-235), then the image becomes more or less, "charcoal" looking. So, in the end, it appears to be best to leave the colors alone, except for the one filter I just mentioned. Leave that one in. It actually does help.
I used DVDfab 10 to rip to the hdd, copy mode, not encoding. I wanted the raw source. The ripping process was very slow, about 15MB/s or 1/2 hr.
Has anyone done any bluray rips of Farscape? and what are your comments as far as the image detail and other aspects of it are? And are you using any color processing? Farscape has a lot of dark scenes in them, like the one I was just testing. S1D5 (disc 5) opening scene.
Code:v = "g:\src\Video\THE_FIFTH_ELEMENT\src.THE_FIFTH_ELEMENT.theatrical.mp4" v = "g:\src\Video\FARSCAPE_S1D5\src.FARSCAPE_S1D5.theatrical.mp4" # LoadPlugin( "c:\PLUGINS\LSMASHSource.dll") # LWLibavVideoSource(v, cache=true , seek_mode=0 )#.trim(0, 100) #.selectevery(2,0) # LoadCPlugin( "c:\PLUGINS\ffms2.dll" ) FFVideoSource(v, fpsnum=24000, fpsden=1001) # ConvertToYUY2( interlaced=false ) # ConvertToYV12 # ColorYUV(off_y=50, off_u=1, off_v=1) # tweak(bright=25, cont=1.5, sat=1.0) ColorMatrix(mode="Rec.709->Rec.601") # ScriptClip( """ subtitle("TheFifthElement bluray', frame " + string(current_frame) + " - " + string(framecount),12,12)""") ScriptClip( """ subtitle("Farscape S1D5, qsv2.58, api-v1.4, frame " + string(current_frame) + " - " + string(framecount),12,12)""") trim( 261, 0 ).trim( 0, 1409) # farscape
I haven't done Farscape since i don't own it but all the blu-ray movies,tv shows that i ripped with mavemkv have no noise in them whatsoever and no color issues,are you listening through a receiver or tv or is the noise not sound but picture quality?
Apologies. I meant, grain. Film Grain. Not noise, though it was ascetically meant for film grain, its more noise than appealing.
Also, I am wondering if they made different mastering version of Farscape. I believe they did that for The Fifth Element. But I don't particularly like the mastering job they did on this version/disc of TFE. -
Some movies i own have film grain and watching it on a 60 " hdtv will look crappy since they didn't have it mind to what quality it would be since they probably viewed it on a 40" when they did their mastering jobs.I view through a 46" sony and it's just barely viewable to the grain you are mentioning.
Farscape is not in true 1080P. They are upscaled from the Pal masters 720 x 576. The rights holders claim the 35mm masters are lost and a true 1080p is not possible. I backed up my original BR's and cropped season 1-2-3 to 16x9 and I didn't notice any increase in noise or grain. I used the original file size to preserve the original bitrate.
Using ColorYUV( levels="PC->TV" ) does help a little bit, though its still too dark for reviewing bluray segments. Obviously, I would remove it before the encoding stage.
Bluray Ripping speeds
By Merchy in forum Blu-ray RippingReplies: 11Last Post: 15th Oct 2015, 11:04 -
Bluray ripping
By slee02 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2015, 18:58 -
Iso bluray ripping
By fjmr in forum Blu-ray RippingReplies: 20Last Post: 31st Aug 2012, 04:53 -
Bluray ripping my bluray collection
By NoLegalMoves in forum Blu-ray RippingReplies: 4Last Post: 24th May 2012, 10:39 -
ripping Bluray
By anathema11 in forum MacReplies: 6Last Post: 20th Dec 2011, 09:32
