I'm seeing a strange 3-3 combing pattern in these DVD's I've been working with lately. Until now I thought it was either true interlaced, where every frame would have combing... or a 2-3 pattern of 2 interlaced frames and 3 progressive frames. What's up with this wonky 3-3 stuff?
Results 1 to 22 of 22
Nothing 'wonky' about it. As jagabo knows, it's usually indicative of PAL to NTSC, and it can usually be restored to progressive 24.975 or 25fps with the right IVTC. It's easy if you're familiar with AviSynth. But, as he mentioned, to be sure a short untouched sample would be needed.
How strange, when I play the source in MPC-HC none of this is there. Only after running it through MeGui is it present. The combing does appear in DgIndex, but once I save a small clip, then in that clip, too, the combing isn't present. My MPC-HC is set up to show any combing that may exist - deinterlacing is set to Disabled (Progressive) in LAV Video Decoder.
Strange... if I just use QTGMC, there's duplicate frames. If I use TFM and Tdecimate, it seems like there's dropped frames...
Of course. It's telecined video. That always has duplicate frames after QTGMC.
Because the frame rate isn't 23.976 fps. It's some other frame rate, hence the different pulldown pattern. Any progressive frame rate from 19.98 to 29.97 fps can use pulldown to create the requisite 59.94 fields per second required by DVD. You have to specify the correct settings to TDecimate() to get the original progressive frame rate. If it has blended fields you'll want to use QTGMC() (or Yadif()) and SRestore() instead. But you may still have to specify the correct frame rate. -
I think I saw that once and after analyzing it, I determined it was 25FPS video. I had to write my own script to make it progressive again because it was not a predictable pattern.
Darryl -
I apologize for that, but as I said before, for some reason in the original sample I saw no combing... only after transcoding it. I guess I could have made a sample of that, but I digress.
In any case, that code seems to have worked. What exactly does that code do, anyway? It resulted in a 24.975FPS video... is this indicative of a PAL-NTSC crossover? -
It performs an IVTC. Instead if doing it for the more common 3:2 pulldown, with those settings it undoes 3:2:3:2:2 pulldown.
...is this indicative of a PAL-NTSC crossover
I guess I could have made a sample of that... -
Then upload a sample of that.
Are you looking for real help or not? Without seeing samples nobody can help you. We can only make guesses from the sparse (and probably unreliable) information you have given.
It field matches frames (making progressive frames whenever possible) and then discards one (hopefully a duplicate) of every six frames.
Maybe. But without a sample of your original source nobody can tell exactly what's going on.
If you had uploaded some samples this would have been solved a long time ago and you might have learned something. -
Okay, same situation, here: 3:3 Pulldown?
Sample: https://www.sendspace.com/file/sjyi8x
Is @manono's script [ TFM().TDecimate(Mode=0,Cycle=6,CycleR=1) ] the best recommendation?
Like OP I was formerly familiar with 3:2, but hadn't yet encountered 3:3.
thanks in advance~ -
It's not really my script, but yes.
Like OP I was formerly familiar with 3:2, but hadn't yet encountered 3:3. -
No. To 'bob' means to create full frames from fields, thus doubling the framerate to 59.94fps. You can put on the built in AviSynth filter Bob (and you'll learn why it's called 'bob' as you notice the frames created bouncing up and down), or you can use Yadif(Mode=1) or put on QTGMC which bobs by default. Or a number of other bobbing filters
I̶ ̶s̶e̶e̶.̶.̶.̶ ̶ ̶s̶o̶,̶ ̶o̶n̶c̶e̶ ̶I̶ ̶d̶o̶ ̶"̶B̶o̶b̶"̶ ̶i̶t̶,̶ ̶h̶o̶w̶ ̶t̶h̶e̶n̶ ̶d̶o̶ ̶I̶ ̶i̶n̶t̶e̶r̶p̶r̶e̶t̶ ̶t̶h̶e̶s̶e̶ ̶p̶u̶l̶l̶ ̶d̶o̶w̶n̶ ̶p̶a̶t̶t̶e̶r̶n̶s̶?̶ ̶ ̶C̶o̶u̶n̶t̶,̶ ̶f̶r̶a̶m̶e̶-̶b̶y̶-̶f̶r̶a̶m̶e̶,̶ ̶a̶n̶d̶ ̶l̶o̶o̶k̶ ̶f̶o̶r̶ ̶d̶u̶p̶l̶i̶c̶a̶t̶e̶ ̶f̶r̶a̶m̶e̶s̶?̶ ̶ ̶S̶o̶r̶r̶y̶.̶.̶.̶ ̶ ̶I̶'̶m̶ ̶s̶u̶r̶e̶ ̶m̶u̶c̶h̶ ̶o̶f̶ ̶t̶h̶i̶s̶ ̶i̶s̶ ̶v̶e̶r̶y̶ ̶b̶a̶s̶i̶c̶.̶ ̶ ̶I̶ ̶a̶p̶p̶r̶e̶c̶i̶a̶t̶e̶ ̶y̶o̶u̶r̶ ̶p̶a̶t̶i̶e̶n̶c̶e̶ ̶a̶n̶d̶ ̶h̶e̶l̶p̶.̶
Edit: Okay... I bobbed the clip using QTGMC and sure enough I now understand what you're saying. I see the 3:2:2:3:2 pattern.
That said, is it just something that folks like you (who have much more experience) know what script(s) to use?
Further, is this practice of Bobbing a good starting point for determining pulldown patterns in the future? I have a lot more videos with seemingly unusual patterns. If you say so, I'll bob them, count the pattern, and then at least have a better starting point in asking for assistance on here from you veterans.Last edited by U2Joshua; 13th Dec 2016 at 14:56.
When dealing with something out of the ordinary, I almost always begin by bobbing it with Yadif(Mode=1). Yadif is fast and I can tell what's going on much more easily than I can with QTGMC, although I'll often use QTGMC for the actual encoding when bobbing is needed before unblending, or (more often these days), yadifmod(mode=1, edeint=nnedi3(field=-2)) (which needs YadifMod and NNEDI3) followed by SRestore(), because it's faster than QTGMC, if not quite as good.
With PAL to NTSC (as yours is) more often than not the conversion involves field blending and bobbing shows the blended fields quite nicely. Then you bob it followed by SRestore at default settings. Sometimes a field blended source can be film and it was field blended to 29.97fps. Then you'd bob it followed by SRestore(Frate=23.976).
Your 6-frame cycle of the unfiltered source is a giveaway that it's PAL to NTSC. And almost a giveaway that it can be IVTC'd. Bobbing it and counting the 3, 2, 3, 2, 2 pattern without any field blending confirms the theory and tells you it can be IVTC'd with those settings given earlier. Field blended PALtoNTSC generally (not always) has 5 out of 6 frames interlaced.
So, once you decide it's not been field blended you can put on:
TFM()
all by itself. Then count how often you see duplicate frames. Every six frames and it's 3:2:3:2:2, every 5 frames and it's 3:2. And you follow TFM with TDecimate at the correct settings. There are lots of ways to figure out what's going on (and others I haven't mentioned) and you'll learn from experience if you're unfortunate enough to have to deal with screwy sources often.Last edited by manono; 13th Dec 2016 at 17:04.
Think about what the 3:2:2:3:2 pattern means: 5 different film frames were converted into 12 fields. Since the field rate of the NTSC video was 59.94 the progressive frame rate was 59.94 * 5 / 12 = 24.975 frames per second. The last issue is whether the 25 fps source was slowed to 24.975 fps before being telecined (almost never) or whether the 3:2:2:3:2 pattern was modified occasionally (most likely) to make up for the difference. It's almost impossible to tell the difference and, in practice, it's not worth worrying about.
That does make sense, @jagabo. Thank you, and thank you, @manono.
How about 25fps PAL DVDs that are known to be from 24fps film sources? I can't quite wrap my head around this one, yet... Lots of conflicting information online, it seems. Here, in this example, there are far more interlaced frames (maybe all?) than progressive.
SAMPLE: https://www.sendspace.com/file/5659us
thanks in advance~Last edited by U2Joshua; 13th Dec 2016 at 20:47.
It was field blended so you unblend it and get back 23.976fps:
QTGMC()###or your bobber of choice
Srestore()
Very common, that kind.
Lots of conflicting information online, it seems. -
Test Pattern on YouTube
By chris319 in forum Video Streaming DownloadingReplies: 44Last Post: 2nd Jun 2016, 10:22 -
Android madness..... too many pattern attempts
By hello_hello in forum ComputerReplies: 14Last Post: 21st Nov 2015, 02:59 -
Strange DVD pulldown pattern
By yiguro in forum DVD RippingReplies: 3Last Post: 2nd Aug 2013, 13:29 -
Help deleting duplicate frames in a pattern
By dexter30 in forum Video ConversionReplies: 7Last Post: 5th Jun 2012, 11:17 -
Which software can do pattern matching on waveforms?
By wiseleo in forum AudioReplies: 7Last Post: 26th Dec 2011, 17:34
