I was VERY bored so I decided to (try to) compile a fresh version of FFmbc.
As usual, I have NOT tested it, therefore, play at your own risk
And more importantly: this time, I did not forget to include xvidcore.dll in the archive
Good luck
Results 1 to 10 of 10
I tested it out a little bit and it seems to work great. Thank you for taking the time to compile it!
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Marsia MarinerGuest
Overdue update...
Apparently the most-recent FFmbc source-code can be compiled by GCC 7.2.0 with no problems
OTOH, I have no idea of how to build an x64 edition of the dämn thing.
After getting the latest LAME, xvid and x264 libs, I will build and release a fresh FFmbc.exe. -
ffmbc can be compiled with help of https://github.com/jb-alvarado/media-autobuild_suite (however i struggle with some issues and never except one time succeeded)
Please note the disclaimer, though...
Code:------------------------------------------------------------------------------- ------------------------------------------------------------------------------- ######### UNSUPPORTED, IF IT BREAKS, IT BREAKS ################################ Build FFMedia Broadcast binary? 1 = Yes 2 = No Note: this is a fork of FFmpeg 0.10. As such, it's very likely to fail to build, work, might burn your computer, kill your children, like mplayer. Only enable it if you absolutely need it. If it breaks, complain first to the author in #ffmbc in Freenode IRC. ------------------------------------------------------------------------------- -------------------------------------------------------------------------------
Seem you reading disclaimers... very rare nowadays...
I'm unable to compile regular ffmpeg build (mentioned before i've succeeded only once and have no clue why - enigmatic message about truncf declaration - not sure why as i'm not a programmer and zeranoe builds are seriously limited - no support for new feature's like sofalizer). -
No panic, there is a known issue right now with an incompatibility between gnutls and openssl, but accidently both being enabled in the build parameter list file if you are using one. Until about 2 weeks ago, I could quite frequently build ffmpeg with MABS. But I don't build ffmbc, have no use for it.
From time to time I delete some parts of the generated scripts just to check whether they are a reason for issues. Therefore I sometimes need to re-enter my preferences when I delete the INI file too. And so I got to read them.
ffmbc wiki gone?
By SameSelf in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2016, 08:04 -
Rewrap using ffmbc and 5.1 audio
By SameSelf in forum Video ConversionReplies: 7Last Post: 23rd Mar 2015, 21:45 -
ffmbc 0.7 RC9 for win?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 30th Apr 2014, 10:23 -
problem with ffmbc
By jack616 in forum Video ConversionReplies: 13Last Post: 23rd Sep 2013, 12:16 -
FFmbc 0.7 for Windows
By Chris K in forum Video ConversionReplies: 0Last Post: 30th Sep 2011, 15:28
