I have one DVD with the audio track out of synch (about 3 seconds) and I want to rip it and make an exact copy, including the same menu and eveything without any changes, but with a synchronized audio. What program should I use and how to do it?
Not much info.
Rip the DVD to HDD with DVDFab HD Decrypter. Use MakeMKV. Open the resulting .mkv file with MKVToolnix and adjust audio. Author a dummy dvd with the new .mkv file with AVStoDVD. Use VOBBLANKER to replace .vob files in the original with those from the dummy. -
I'd do it slightly differently.
Decrypt the DVD to the hard drive. videobruger's suggestion of using DVDFab HD Decrypter will do it, although I usually prefer DVDDecrypter if there's no advanced copy protection. Figure out the amount of the delay. Demux video, audio, subs (if any), chapters (celltimes.txt) using PGCDemux. Take the audio file and remove the delay using DelayCut. Reauthor everything using Muxman. Put the new and fixed DVD back into the original one using either PGCEdit (unless it's a complex DVD) or VobBlanker.
Both methods should work, I think.
Adding an audio track and subtitle track to a DVD?
By killerteengohan in forum Authoring (DVD)Replies: 2Last Post: 9th May 2015, 18:35 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 06:53 -
Software for syncing and muxing audio track with video track?
By uranometria in forum Video ConversionReplies: 1Last Post: 21st Jul 2014, 01:52 -
Add an audio track or replace the audio track of an AVI
By abrafax in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2012, 14:34 -
Audio only out of synch on DVD player
By canadian1969 in forum DVD RippingReplies: 3Last Post: 31st Aug 2011, 16:38
