Okay I'm not a total newbie, I've made hundreds of VCDs and SVCDs, but now that I've got a DVD burner, I have a question I can't seem to solve.
When I rip a DVD I nearly always get 23.976 fps video right? I understand that some sort of tag is added to the video to make it 29.970 fps when it's played back (3:2 pulldown right?).
Why then do all the DVD authoring programs I have insist on 29.970 fps videos? I've tried DVDit, ULead Moviemaker and SpruceUp, they all reject anything at 23.976 (I'm using TMPEGEnc to make the MPEG2 files). And yes, I tried setting TMPEGEnc to 23.976 and checking the "3:2 pulldown" box, still rejected.
How do I either get the authoring SW to accept such MPEGs or do whatever is necessary to use 24 fps video as a source?
Thanks,
James Bell
newsw@eudoramail.com
U could try using "pulldown.exe" to add the proper flags to all sequences & frames. Not sure it will work. I used DVD Wise & DVD maestro and never had a problem with it accepting the 23 fps or 29 fps format for NTSC
Yep, pulldown.exe should do the trick. I use this to get DVDitPe 2.5 to accept Mpegs produced with Tmpgenc. Using the Tmpgenc 3:2 pulldown flag doesnt seem to work. I also find that with DVDit PE I have to set the Number of P picture in Gop to 4 rather than the NTSC DVD templates value of 5. MyDvd doesnt seem to mind this value being 5
Pulldown.exe did do the trick. A pain to use though, a DOS app and you have to demultiplex, use it and multiplex again.
Does anyone know why TMPEGEnc's 3:2 flags don't work? Or why Authoring software can't add the flags?
Thanks for the help
JB
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
Convert 29.967 to 29.970
By jin007 in forum Newbie / General discussionsReplies: 11Last Post: 17th Jul 2008, 13:09 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
Statistics
Newest guides
Latest tool updates
New media comments
