I just got my PDA and i want to play some clips but my pda has only 80meg and i want to run about 300 meg avi file. How do i make high quality avi to low quality avi to make it small size?
Drop the resolution and bitrate, decimate the framerate.
which program do i use?
If you have a PocketPC (Microsoft-based OS) PDA, use Windows Media Encoder. It will convert .avi to .wmv, and make it any file size you want. it even has extra "profiles" specific to certain PDA's. I have encoded a full-length movie at watchable quality for my PDA in a 100mb filesize. If you are not using a PocketPC, then I don't know what to tell ya. Go to windowsmedia.com, go to the download page for windows media player, and it should be in the drop-down box for selecting a download.
Did it--works great....(avi to windows media--compresses about an hour to I think around 30 mb)
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum CapturingReplies: 2Last Post: 22nd Dec 2011, 10:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
how to upload high quality vid? found 1 upped after february
By bojadada in forum Video StreamingReplies: 4Last Post: 30th Oct 2008, 15:42 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
