Ok, so I'm pretty sure that all Sony "i.LINK/Firewire" ports are 4-pin...
But if I get a 4-pin to 6-pin or 4-pin to 9-pin cable, will that speed up the data transfer?
Thanks!
Results 1 to 11 of 11
Anon45Guest
9-pin firewire ?
The answer is no since transfer is in real time. A one hour recording will take one hour to transfer. -
9 pin Firewire = FireWire 800 (IEEE 1394b-2002) (see here: https://en.wikipedia.org/wiki/IEEE_1394 )
As DB83 says though, Firewire (or 'i.link') tape transfer is always in real time.... -
And to be on the safe side always connect your pc to your camcorder when everything is turned off. There are some firewire horror stories to be found.
https://forum.videohelp.com/threads/376401-how-do-I-keep-my-PC-s-from-burning-out-the-1...-on-my-cameras -
4 pin, 6 pin. The two extra wires/pins are for power.
From the Wikipedia article referenced above:
The 6-conductor powered connector, now referred to as an alpha connector, adds power output to support external devices. Typically a device can pull about 7 to 8 watts from the port; however, the voltage varies significantly from different devices.[26] Voltage is specified as unregulated and should nominally be about 25 volts (range 24 to 30). Apple's implementation on laptops is typically related to battery power and can be as low as 9 VLast edited by redwudz; 3rd Mar 2016 at 10:26.
Anon45Guest
Yes, but I read that 9-pin can transfer up to 3200Mbps.
And 4-to-6pin can transfer up to 1600Mbps.
Wish I wrote down the source... -
^^ The wiki article does quote those transfer rates.
But it does depend what you are transferring. If you have an external storage device such as Hard Disk that supports the interface then, yes, theoretically it is achievable.
But you are asking about a ilink transfer and that means video. In fact all video transfer is in real time - video tape could be copied in a plant faster and dvds can be copied faster than 1x but neither concern this thread.
Looking for a good ieee 1394 PCI card
By EZ Video in forum CapturingReplies: 5Last Post: 12th Aug 2014, 21:45 -
IEEE 1394 Capture from DVHS on Windows XP SP3
By Shelby68GT500 in forum CapturingReplies: 2Last Post: 28th Nov 2012, 16:07 -
Camera - IEEE 1394, Compsite and mic in???
By djlerman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Jan 2012, 23:58 -
My IEEE 1394 cable can't be detected
By edhani in forum CapturingReplies: 1Last Post: 14th Jul 2011, 07:19 -
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 04:28
