This software is way over my head. I would like to know how to convert, author or render an AVI movie file and burn it to DVD. Can u point me towards a simple to understand tutorial that will help. The software instructions and tutorials direct me to tabs or drop downs ETC that I can't find.
Another problem is when adding an MKV or AVI file I get error telling me that "the selected file is not of the required type"
Thanks for your time. Frank
Wrong program.
This software expects dvd-compliant video/audio. It does not re-encode from other formats.
Use another program such as avstodvd to create your compliant mpeg2. Or just use this to create your dvds.
It is a good program but takes some learning. The user-guide is quite good in my opinion.
BTW This is in the wrong forum
DVD Architect Pro 5.2 - Dual Language Menu
By Neutral42 in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2012, 13:06 -
DVD Architect Pro 5.2 not updating prepare files
By cdavis in forum Authoring (DVD)Replies: 0Last Post: 21st Jun 2012, 14:20 -
Audio POPS! with DVD Architect Pro 5.0
By Dissonance in forum Authoring (DVD)Replies: 2Last Post: 21st May 2012, 15:45 -
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 07:55 -
Flicker / movement on Authored DVD (Architect 4.5 pro).
By Compo in forum Authoring (DVD)Replies: 4Last Post: 25th Jun 2011, 12:59
