Hello internet!
I bought a JVC 9911 from ebay but I'm not sure if it is in working order.
When I plug the unit into the power, word "Auto" blinks in the front screen of the 9911, which manual says it means it is trying to set the clock automatically. After some time it gives up and I'm left with "--.-- " on screen. 'Power' button on the unit doesn't do anything, and when I connect the out put to a TV (I've tried component and S-Video) nothing works (even pushing menu button on remote doesn't show anything in the output.
If this unit is supposed to be powered on regardless of the clock, then I assume there is something wrong. Also without the device being powered on, am I supposed to use the remote?
Best,
Morteza
Stick a tape in it and press play?
My JVC/Philips tries the same thing, I just start using it and it gives up. -
My first JVC/Philips did some strange stuff before I got pissed off and killed it, now that I think of it it was THAT machine that occasionally did that....my present one has never done that.
Yes, that's normal behavior. This model was designed back when PBS television stations offered time-setting as an Extended Data Service. With the rise of digital broadcasting and internet time protocols, the service is no longer broadcast.
1. Press the TIMER button to disengage timer mode. Then try the POWER button.
2. Press and hold the POWER button for more than 10 seconds to cancel Child Lock function.
3. Leave the unit unplugged from AC power for several minutes and try again.
JVC HR-S9911U brightness pulsing
By JVRaines in forum CapturingReplies: 2Last Post: 1st Aug 2015, 20:54 -
GPU powered HEVC encoding is here, sort of.
By sophisticles in forum Video ConversionReplies: 15Last Post: 22nd Sep 2014, 11:25 -
Should I upgrade my VCR from a JVC Hr-S9911u to an older
By etecnifibre in forum RestorationReplies: 76Last Post: 28th Aug 2014, 21:26 -
h1 vs h4n for phantom powered condenser lavalier that can use battery
By gtxrla in forum Video Streaming DownloadingReplies: 6Last Post: 14th Mar 2013, 15:10
