  1. I'm a MEGA Super Moderator Baldrick's Avatar
    Using XMedia Recode can you rotate and flip any video.
    Software:
    XMedia Recode (FREE!!!)
    Guide:
    Open your file.
    Under Format choose for example Profile: Custom, Format: MP4 . (You could also make avi, mkv, mov, etc)
    Under the Audio tab choose Mode:Copy
    Under the Filters/preview tab click Add filter and choose Rotate.
    Select the Rotate Filter, enable it and choose rotation degree.
    Last Click Add to Queue and Encode!
    Check the Destination folder for your new video file.
    Done!
    Flip video(horizontally or vertically):
    You can also Flip your video, under Filters/Preview add the Flip image filter.
    Other tips:
    Under the Video tab can you adjust the quality.
    Under Bitrate try increase to it 2000-10000. Or change to Rate control mode: Constant Quantizer and try a value between 10-20(lower value=higher quality).
    Jan 2007
    Nice tutorial..
    If you had done a left rotate aka -90 or 270
    You would not need flip
    Yes flip is handy
    But better one operation instead of two or three
    Thanks..
    I need to check out Xmediarecode, avidemux has needs my fall back for years
  3. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    Thanks, you solved my problem before I knew I had one!
