I have two powerpoint presentations that need to be converted to avi or mpeg. They are about 25 minutes long each. Obviously you need a capture card and a program that will record everything on the screen in real time, as well as a fast computer and a huge hard drive. Would anyone be willing to convert them for money? If you are willing, please e-mail me at: hhshusky2002@satx.rr.com
No jokes please. Only real offers. Thank you.
well, if they aren't fullscreen... you can use Hypercam... that seems to do the trick
Do a search for "camtasia". That is the program you want. It as its own compression codec. You specify which window or full screen to capture and the number of frames per second and it creates the avi as it goes. If you then want mpeg, use tmpgenc to make the mpeg. Its really very simply
why not just export the slides as still images and make those into MPEGs/AVIs or even better use VCD Toolkit from Phillips to do stills and clips as a VCD. you can set duration, etc.
Capturing clips from DVD's to embed in PowerPoint presentations?
By billy_ball2 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2013, 12:27 -
Convert PowerPoint to Video
By TBaker14 in forum Newbie / General discussionsReplies: 7Last Post: 9th Nov 2011, 00:41 -
convert swf to anything that can be called from powerpoint
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2010, 06:24 -
How do i make a composite video of a talking head plus powerpoint slide?
By johnbaldry99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2009, 17:28 -
Feedback on software for converting Powerpoint Presentations to Video
By LJB in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 09:21
