I don't know where to ask this question.
Recording s-video feed on a Panasonic DMR-EZ28.
Source is a Comcast DTA HDMI out through a conversion box.
BTW, the HDMI to s-video box tests out to being 720 input even if it can handle higher and lower.
I'm satisfied with the results, not perfect, definitely not bad.
What tools are available to report on the technical details of recorded content? That is, tools to give frame rate, bit rate, pixel dimensions, and beyond.
Yes, I know I can right click a file and get a properties sheet. But that doesn't really explain why the picture is so good.
What I mean is, using coax output from the DTA the recording is SD and it really looks like a 20 year old VCR tape. Through the conversion setup recording is still SD dimensions but the colors are better and it fills the screen properly. By "properly" the best example is screen graphics on the perimeter. They are cropped, top bottom and sides with coax. With s-video and 4:3 forced it looks goofy but everything is there so 16:9 looks great, but it's still SD being reported in properties. Old cinemascope type movies, letterbox, look darn good.
Can someone tell me what's going on? Happy but confused. No need to get all verbose or anything, keywords or a link will do. TIA
This section works fine if you don't know where to post or if it cover several sections. But I guess dvd recorders would work also.
Now just click on Edit and Go Advanced to change your thread title to something better....
You can use mediainfo to get most details from the video files. -
Output type. S-Video always looked better than coax (even from the same source (VCR & tape) to the same display), which is why it was so popular with those looking for quality. So it's not surprising you are seeing the same difference when recording.
Google is your Friend
req adv: webcasting services
By neuronetv in forum Newbie / General discussionsReplies: 7Last Post: 4th Apr 2015, 15:08 -
Before / After, Post your Sample here ! Official Topic
By Caiosouza in forum RestorationReplies: 5Last Post: 30th Nov 2013, 11:52 -
Newbie To The Forum Blu Ray Copying Question
By houst1380 in forum Blu-ray RippingReplies: 6Last Post: 25th Apr 2013, 08:03 -
Embed Webcam Video Recorder in Every Post of My Forum for Users
By Dave234 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Mar 2012, 02:08 -
Back-up question (somewhat off-topic)
By danielmak in forum MacReplies: 2Last Post: 20th Dec 2011, 16:20
