Personally I would like to backup my home video VHS tapes that are over 10 years old.
Now my question is, if I record from VHS into my digital 8 camera onto a hi8 or 8mm tape and captured the VHS film, would the copy be near a 100% since its recording somewhat digitally (although not actually digital).
What would be an approximate percentage of the original if I went from VHS to regular 8mm and VHS to Hi8 (using my digital camera as a recorder)?
thanks anyone have a clue?![]()
There would be some loss of quality simply by virtue of the fact that the video will be traveling through your VCR and through analog cables to your camera. If you record digitally onto a Hi8 tape you will probably not notice a change in quality, or at least only a small one. If you record to an analog copy, you will lose quality, and then every successive copy with degrade further. My suggestion would be to record your VHS tapes onto a Digital 8 camera using a Hi8 or better still the HME tapes which are higher quality and longer recording time (albeit a bit expensive).
There are other options, and my recommendation would be to record onto a computer and then onto a CD-R or DVD-R. The problem with any tape recording device is that tape is very susceptible to decay and CDs or DVDs are much longer living.
Best of luck!
How much quality loss would there be on a VHS to HI 8 and VHS to 8mm tape using my digital camera?
Also if i made a copy on my Hi8, how long until the tape starts to degrade?
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
Question: Long horizontal scratches on VHS tape
By bisonrav in forum RestorationReplies: 12Last Post: 6th Mar 2010, 07:09 -
Trying to get a good digital capture of an old VHS tape
By StrobeLightEpileptic in forum RestorationReplies: 2Last Post: 21st Nov 2009, 21:16 -
Will a Digital 8 camcorder read 8mm tape?
By TN Vol in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 10th Jun 2009, 13:24 -
Question about capturing VHS tape to .avi file
By rfdillon in forum CapturingReplies: 6Last Post: 27th Jul 2008, 00:44
Statistics
Newest guides
Latest tool updates
New media comments
