Hello,
my Cyberhome starts to flicker and breaks down to a blue screen (yes, same like the PCs, but without the error message): Does anybody know how to switch off the Macrovision copy protection or to remove the flickering?
greetings
I don't hink you can disable macrovision on the 528 without a hardware chip, although it was quite easy on the 512. Check out the forum at www.cyberhome-help.de
Have you been able to get your 528 to play VCD's created with TMPGenc without the picture "stuttering" every few seconds? No matter what I do I can't get rid of this problem. It also affects the software DVD player "Power DVD 4xp". I've noticed this on a lot of different machines. It's actually one reason why I burn SVCD's as they are a lot more stable in the 528!
I have a similar problem with some VCD's. They doesn't seem to be any thing wrong with the VCD when played on a PC but when played on the 528, it stutters every now and then. This appears to be a problem with a non PAL vcd, but if you have any idea's....Have you been able to get your 528 to play VCD's created with TMPGenc without the picture "stuttering" every few seconds? No matter what I do I can't get rid of this problem. It also affects the software DVD player "Power DVD 4xp". I've noticed this on a lot of different machines. It's actually one reason why I burn SVCD's as they are a lot more stable in the 528
I found that if I use xVCD or CVD MPEG2 the Cyberhome player (and indeed Power DVD) will play it perfectly. It's just basic VCD's that they don't like.
Might it make a difference if you select PAL or NTSC to match the VCD? I notice it's not auto-detecting.
Cyberhome AD-L 528 Crashes with DVD+R
By christaltips in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Dec 2011, 06:54 -
CyberHome DVD Recorder
By JRPAT in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Sep 2008, 18:08 -
Cyberhome DVR1600ME2 firmware
By DogDoor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2008, 15:45 -
cyberhome 300s need a firmware update
By etrin in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Dec 2007, 06:12 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 08:28
