VideoHelp.com Forum
  1. when I render a movie for 27 minute, I need to wait for 2 to 3 hours only then I can get the result by using Ulead MediaStudio Pro 6.0. Any method to speed up the rendering time?
    Please describe your rendering process more detailed:
    1. what is the format of the source ? (analog/DV/DVD/other)?
    2. what is the resulting format ? (avi or mpeg-1/2)
    3. Are you using any filters and/or frame cropping ?
    My source is DV avi, so the rendering times are:
    avi to avi: 30-50 frames/second
    avi to mpeg-1: 10-20 frames/second
    avi to mpeg-2: 7-10 frames/second
    i.e no filtering or cropping involved.
    This means, 30 min footage are rendered from 15 min to 1.5 hours, depending on type of result.
    Rendering from mpeg-2 sources (DVD) adds about 1 hour per vob.
  3. Member Snakebyte1's Avatar
    Hi..
    I had a similar problem with MediaStudio5, when I went to PREVIEW. It took forever to render the file. The solution was to change the resolution of the preview window.
    I'm not sure if your problem is the time it takes to render a preview or to render the final video file, but if its the preview start by making sure the preview window is the same size as your source AVI files. If so then try lowering the resolution of the preview window. This should not affect your final output, only the preview.
  1. Ways to speed up rendering with VirtualDub + Avisynth?
    By Asterra in forum Newbie / General discussions
    Last Post: 18th Apr 2011, 10:20
  2. Rendering time changed
    By liqt in forum Editing
    Last Post: 8th Jan 2011, 13:50
  3. how to speed up rendering time with HD video
    By The Linguist in forum Newbie / General discussions
    Last Post: 17th Dec 2009, 05:31
  4. FCP 6: Question about rendering speed and time
    By wheelandtorque.com in forum Mac
    Last Post: 19th Oct 2009, 14:24
  5. Replies: 4
    Last Post: 25th Jan 2008, 17:45
