This auto-logout is a reasonable feature to have, but the default timeout is excessively short and the frequent prompts for login have grown annoying to the point that I sought to modify it but cannot see where to.
Is this possible? Can it be simply disabled or set to a high value such as 14 or 30 days (common elsewhere)?
Select Remember Me and you only have to login if you get a new IP. And you must have cookies enabled.
Or does that not work? -
Thanks for your reply.
No, that didn't work, "Remember Me" was checked - but your suggestion I traced it to a cookie issue and whitelisted videohelp.com, which did the trick.
Although clearly videohelp.com doesn't use them maliciously, generally speaking, it's a shame cookies still exist at all. That's another topic though, for an off-topic thread. You can close this one.
DOS batch: looking for user input (Y/N) with a timeout
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 16th Nov 2014, 06:22 -
Login navigation messed up ...
By Hoser Rob in forum FeedbackReplies: 7Last Post: 21st Mar 2013, 10:50 -
ffmpegx login problem
By Tiger Bear in forum MacReplies: 1Last Post: 9th May 2012, 15:51 -
avcodec_decode_video Timeout
By james_watt20 in forum ProgrammingReplies: 0Last Post: 18th Jan 2012, 02:03 -
Linux Login
By Nelson37 in forum LinuxReplies: 16Last Post: 9th Jan 2011, 09:52
