GUYS...really need your help.
I am newbie in this thing. first time ever using dvdflick. i tried burn to dvd for many attempts already but it keep telling me the same error
I 15:18:35 ImgBurn Version 2.4.4.0 started!
I 15:18:35 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
I 15:18:35 Total Physical Memory: 1,038,636 KB - Available: 278,476 KB
I 15:18:35 Initialising SPTI...
I 15:18:35 Searching for SCSI / ATAPI devices...
I 15:18:38 Found 1 DVD±RW/RAM!
I 16:10:36 Operation Started!
I 16:10:36 Building Image Tree...
I 16:10:36 Checking Directory Depth...
I 16:10:36 Calculating Totals...
I 16:10:36 Preparing Image...
I 16:10:36 Checking Path Length...
I 16:10:36 Contents: 1 File, 0 Folders
I 16:10:36 Content Type: Data
I 16:10:36 File System(s): ISO9660, UDF (1.02)
I 16:10:36 Volume Label: Video
I 16:10:36 Size: 708,278 bytes
I 16:10:36 Sectors: 346
I 16:10:36 Image Size: 1,277,952 bytes
I 16:10:36 Image Sectors: 624
I 16:10:36 Operation Successfully Completed! - Duration: 00:00:00
I 16:10:36 Source File: -==/\/[BUILD IMAGE]\/\==-
I 16:10:36 Source File Sectors: 624 (MODE1/2048)
I 16:10:36 Source File Size: 1,277,952 bytes
I 16:10:36 Source File Volume Identifier: Video
I 16:10:36 Source File Application Identifier: IMGBURN V2.4.4.0 - THE ULTIMATE IMAGE BURNER!
I 16:10:36 Source File Implementation Identifier: ImgBurn
I 16:10:36 Source File File System(s): ISO9660, UDF (1.02)
I 16:10:36 Destination Device: [0:0:0] TSSTcorp CD/DVDW TS-L632D HH18 (D (ATA)
I 16:10:36 Destination Media Type: DVD-R (Disc ID: MJC M005) (Speeds: 2x, 4x)
I 16:10:36 Destination Media Sectors: 2,298,496
I 16:10:36 Write Mode: DVD
I 16:10:36 Write Type: DAO
I 16:10:36 Write Speed: 1x
I 16:10:36 Link Size: Auto
I 16:10:36 Lock Volume: Yes
I 16:10:36 Test Mode: No
I 16:10:36 OPC: No
I 16:10:36 BURN-Proof: Enabled
I 16:10:39 Filling Buffer... (40 MB)
I 16:10:40 Writing LeadIn...
W 16:10:57 Failed to Write Sectors 0 - 31 - Reason: Power Calibration Area Error
W 16:10:57 Retrying (1 of 20)...
W 16:11:09 Retry Failed - Reason: Power Calibration Area Error
W 16:11:09 Retrying (2 of 20)...
W 16:11:28 Retry Failed - Reason: Power Calibration Area Error
W 16:11:28 Retrying (3 of 20)...
W 16:11:43 Retry Failed - Reason: Power Calibration Area Error
W 16:11:43 Retrying (4 of 20)...
W 16:11:56 Retry Failed - Reason: Power Calibration Area Error
W 16:11:56 Retrying (5 of 20)...
W 16:12:07 Retry Failed - Reason: Power Calibration Area Error
W 16:12:07 Retrying (6 of 20)...
W 16:12:21 Retry Failed - Reason: Power Calibration Area Error
W 16:12:21 Retrying (7 of 20)...
W 16:12:33 Retry Failed - Reason: Power Calibration Area Error
W 16:12:33 Retrying (8 of 20)...
W 16:12:46 Retry Failed - Reason: Power Calibration Area Error
W 16:12:46 Retrying (9 of 20)...
W 16:13:01 Retry Failed - Reason: Power Calibration Area Error
W 16:13:01 Retrying (10 of 20)...
W 16:13:15 Retry Failed - Reason: Power Calibration Area Error
W 16:13:15 Retrying (11 of 20)...
W 16:13:29 Retry Failed - Reason: Power Calibration Area Error
W 16:13:29 Retrying (12 of 20)...
W 16:13:42 Retry Failed - Reason: Power Calibration Area Error
W 16:13:42 Retrying (13 of 20)...
W 16:13:54 Retry Failed - Reason: Power Calibration Area Error
W 16:13:54 Retrying (14 of 20)...
W 16:14:06 Retry Failed - Reason: Power Calibration Area Error
W 16:14:06 Retrying (15 of 20)...
W 16:14:18 Retry Failed - Reason: Power Calibration Area Error
W 16:14:18 Retrying (16 of 20)...
W 16:14:29 Retry Failed - Reason: Power Calibration Area Error
W 16:14:29 Retrying (17 of 20)...
W 16:14:46 Retry Failed - Reason: Power Calibration Area Error
W 16:14:46 Retrying (18 of 20)...
W 16:14:58 Retry Failed - Reason: Power Calibration Area Error
W 16:14:58 Retrying (19 of 20)...
W 16:15:09 Retry Failed - Reason: Power Calibration Area Error
W 16:15:09 Retrying (20 of 20)...
W 16:15:21 Retry Failed - Reason: Power Calibration Area Error
W 16:15:23 Retrying (21)...
HOW TO FIX THIS???? HELPPP MEEEE
Clearly something is not going well burning the DVD. It could be the DVD-drive, it could be the media.
But first I'd suggest that you install the latest version of ImgBurn and give it another go.
Since DVD-Flick is used to use its own internal copy of ImgBurn, make sure to change the DVD-Flick settings so that it will use your new installation of ImgBurn.
Also check the ImgBurn support forum -
Here's one opinion of your disks with the media code shown in your post:
If you can get these locally, try them.
http://www.bestbuy.ca/en-CA/product/verbatim-verbatim-16x-4-7gb-dvd-r-100-pack-95102/10076421.aspx -
Assuming from drive model its a laptop your talking about.
1: Try verbatim .. no go then 2
2: Replace drive
Buy an external burner ... a desktop model in an enclosure with its own power supply will give plenty of service ... thou if laptop is usb 1 only it can take a while.
3: Replace laptop ... replacing a possibly worn ps circuitry generally not feasible considering tech charges -
Yes, likely media. At least that's easy to change.
Power Calibration Error: The burner does a 'test' burn in a special area towards the center of the DVD disc. Then I believe it reads that and if the read fails you get a 'power calibration error'. It can be caused by: Low quality DVD media, wrong firmware on the drive that isn't calibrated for your DVD media brand and type, a failing or dirty laser on your drive. (A dirty laser lens is not uncommon with a laptop drive as the laser is exposed. )
ImgBurn should be able to tell you the firmware version in your burner and you may be able to find an update. But I would first try some better media, then try cleaning your laser lens. If you continue to have problems, then an external burner may be the easy solution.
DVDFlick Re-Encoding
By bolintx in forum Authoring (DVD)Replies: 22Last Post: 31st Jan 2016, 16:30 -
Nero AAC error [URGENT HELP NEEDED]
By Fahim Adib in forum AudioReplies: 2Last Post: 15th Feb 2013, 04:48 -
DVDFlick Error 53 File Not Found
By NightShade71 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2012, 10:36 -
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
need help with dvdflick
By shashgo in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2010, 00:24
