I have an old Ilo DVD recorder. I don't know if it is wearing out from age, or if it has always produced discs that most programs would not like. Either way, I need to find a way to back up my Recorder discs without using the recorder itself. So far I have tried a number of programs, but the only one that has been able to open the disc and make an iso of it is CloneDVD, which I can't afford.
Everything except CloneDVD says they can't read the disc. CloneDVD processes it with no problems, but says it had to fix some issues in the process. But now the CloneDVD trial has run out ... what other programs are good for managing to copy Recorder DVDs?
I'll try that. Thanks. Why do these DVD Recorders have to be so difficult?!? :
Only a few make strange discs.....my dad owned one too.
You can also try VOB2MPG then reauthor a new DVD. Or if your disc has only one VOB file, you can try loading that VOB file into AviDemux, then outputting it as an MPEG-PS (.mpg) file THEN reauthoring. I remember my dad sending me one of his, and I had to "fix" it like you are trying to do......but I forgot exactly how i did it.
discs finalized on different dvd recorder than the one recorded on
By nocturnalwonder in forum DVD & Blu-ray RecordersReplies: 13Last Post: 15th May 2014, 18:49 -
DVD-recorder not finalizing on Verbatim -RW2 discs
By TheNorwegian in forum MediaReplies: 1Last Post: 17th Dec 2013, 04:30 -
Panasonic VHS/DVD Recorder always creates full discs - but they're not??
By Gibson's Squares in forum MacReplies: 5Last Post: 11th Dec 2012, 13:53 -
Evil Sony DVD Recorder Messes Up Discs
By matthewjohn23 in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Jun 2011, 21:00 -
targa dvd/vhs recorder won't recognise dvd+rw discs.
By steve6 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 31st Jan 2011, 16:04
