hi
does ... I'm really wondering because this powerful software (VCDEASY) with so many options doesn't have the SAVE option
or maybe I couldn't find it ?
HELP it!
Thread: VCDEASY SAVE OPTION
No, there's no save option yet. The closest thing to a save option is the "generate XML". That saves everything you've defined for the VCD (play items, chapters, interactivity, etc.), and you can use it to generate the cd image. But if you need to change anything later, you'll have to edit the xml in a text editor. You can't load it back into VCDEasy and then edit it.
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 14:55 -
SubRip doesn't give me option to save srt
By diamondback in forum SubtitleReplies: 7Last Post: 13th Jun 2010, 08:59 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Where in the world did my "save option" go?
By capman21 in forum ComputerReplies: 4Last Post: 28th Aug 2008, 01:43 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
Statistics
Newest guides
Latest tool updates
New media comments
