http://www.bbc.co.uk/programmes/b03j5qvv
the website uses a flash player that uses rtmp (whatever that is).
I want to record the stream (direct to hard drive if possible) in the format it is streamed in so that i can play that without re encoding .
is that possible ??
perhaps with ffmpeg ??
Hi
With this program ---> https://squarepenguin.co.uk/
Use this command:-
Code:get_iplayer --type=radio --pid=b03j5qvv
Code:General Complete name : BBC_Radio_1s_Essential_Mix_-_Live_at_Manchesters_Warehouse_Project_2013_Sasha_and_Pete_Tong_B2B_with_Eats_Everything_b03j5qvv_default.m4a Format : MPEG-4 Format profile : Apple audio with iTunes info Codec ID : M4A File size : 111 MiB Duration : 2h 0mn Overall bit rate mode : Constant Overall bit rate : 129 Kbps Album : BBC Radio 1's Essential Mix Album/Performer : BBC Radio Track name : Live at Manchester's Warehouse Project 2013: Sasha and Pete Tong B2B with Eats Everything Grouping : Music Performer : BBC Radio 1 Composer : BBC iPlayer Genre : Music ContentType : Music Recorded date : UTC 2013-11-30 01:00:00 Tagged date : UTC 2014-11-07 12:13:44 Writing application : Lavf56.12.101 Copyright : 2014 British Broadcasting Corporation, all rights reserved Cover : Yes Lyrics : / / EPISODE / http://www.bbc.co.uk/programmes/b03j5qvv Comment : The Essential Mix @ 20 celebrations kick off with a show recorded at Manchester's Warehouse Project. Sasha's on the decks, plus Pete Tong, Back 2 Back with Eats Everything. Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2h 0mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 110 MiB (99%)
thank you so much
when i download it is about 45MB.
do you know how i can down load the raw stream or the 110MB shown above??
perhaps a better question would be is the 110MB file the source file from which streaming is being done ??
once again thanks -
