hi
In my mac whit Yosemite I canīt run the tsMuxeR , would have worked fine before, there would be some solution???
thanks
Results 1 to 14 of 14
If you are remuxing blu-rays/avchd/m2ts can you try mkvtoolnix. It support m2ts, blu-ray playlists, etc. But it can only output mkv then....
For now I've settled with parallels desktop and using tsMuxeR for Windows. I need to create jmbd, with mkvtoolnix can not be.
There will be a future solution to yosemite??
thanks for the answers and sorry for my English -
hey zizux!
could you explain (or is there a trick) how you got it work with yosemite? still get error codes:
tsMuxeR(1629,0x7fff773ea300) malloc: *** error for object 0x7fcf4be00a50: incorrect checksum for freed object - object was probably modified after being freed.
*** set a breakpoint in malloc_error_break to debug
or where can i get the command line version?
thanx a lot! -
wouldn't count on it since the developer seems to have abandoned the project once more,... (may be he will be back in a year or two,...)
users currently on my ignore list: deadrats, Stears555 -
oh no! just was searching hours for a tool like this... and now so could you recommend any similar tool for os x? i just want to take some mkvs (with no re-encoding, so just muxing) and want to burn a "real" blu-ray. don't need any menues or extras... just a playable blue-ray.
thanx again!!!
