  1. Hi all,
    The question is in the title : I have mp4 movies I would like to convert to avi (DivX) keeping both quality and file size...
    How can I do please??
    You can try an older version of handbrake (0.9.3 or older http://www.videohelp.com/tools/HandBrake/old-versions#download ). Convert to avi with xvid video.
    But you will lose quality. How much depends on the video source. You can try increase the output file size/bitrate if you lose too much quality.
  3. thanks a lot, I'll try that!
    I don't really care about losing a little quality as long as the movie is not worse than a screener
  4. handbrake doesn't seem to work, when I click start I just get input info in the activity window but that's all
  5. ok my mistake, I reloaded it and works well!
  6. [SOLVED] Thanks a lot the video comes out by 730mb and the quality loss is nearly un-noticable!
