Page 1 of 5
1 2 3 ... LastLast
Results 1 to 30 of 135
  1. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I'm posting my Virtualdub External Encoder preset along with a quick tutorial on how to use it. You'll need to download the encoders and muxers and put them on your HDD somewhere. Then you'll need to edit the paths to the encoders and muxers.
    Here are what you'll need to get:
    AVC (x264)
    HEVC(x265/Divx265)
    Mpeg-2 (ffmpeg)
    AAC (Nero)
    ac3 (ffmpeg)
    mp2 (ffmpeg)
    DTS (dcaenc)
    mp4 (MP4Box)
    mkv (MkvMerge)
    mpg (ffmpeg)
    Animated GIF (ffmpeg)
  2. Member racer-x's Avatar
    Mar 2003
    I figured out how to export to ProRes from virtualdub via external encoder. You will need ffmpeg. Get the latest and you can use 64-bit version, even if you use 32-bit Virtualdub because the data is pipped to the encoder. I use 64-bit versions of all encoders and muxers for speed and greater memory use.
    Prores is a good intermediate codec. I use it after Deshaker for example. Rename the attached file to: ProRes.vdprof , then import.
  3. Member Cornucopia's Avatar
    Thanks racer-x, adding this preset to my toolkit!...
  4. can Mainconcept totalcode as set as external encoder of virtualdub?
  5. Member racer-x's Avatar
    Mar 2003
    Probably, if you use the right commands and have access to the encoder exe. I don't have is, so I can't help.
    Worst case scenario, you could use virtualdub's frameserver to frameserve to any encoder the accepts avi.
  6. I have try using virtualdub to frameserve totalcode but he don't accept, but I have to do other proofs
    Nov 2002
    Encoders must be command line and must accept stdin "-" from pipe.
    Here are most of the proven encoders so far...
    Known Video Command Line Encoders:
    cuda.exe (have to get from Selur)
    divx265.exe (hevc)
    ffmpeg.exe 32-bit (several different formats)
    ffmpeg.exe 64-bit (several different formats)
    mencoder.exe (x264 and ?)
    mpeg2enc.exe (mpeg2)
    vp8/vp9 (for WebM)
    x264 64-bit
    x264 32-bit
    x265.exe (hevc)
    xvid_encraw.exe (I could not get this encoder to work. Use ffmpeg instead)
    Known Audio Command Line Encoders:
    aften.exe (ac3)
    faac.exe (aac)
    fdkaac.exe (this is an autobuild file)
    lame.exe (need lame_enc.dll in same folder)
    neroAacEnc.exe (aac)
    oggenc2.exe (ogg for WebM)
    WMAEncode.exe
    Known Command Line muxers:
    dsmux.exe
    32-bit mkvmerge.exe
    64-bit mkvmerge.exe
    32-bit mp4box.exe (need js32.dll in same folder)
    64-bit mp4box.exe
    ...you can either download these encoders or you could download Selur's Hybrid program and copy the contents of the main folder to your Tools folder. There are a couple that are missing from Hybrid because of licensing (neraacenc.exe).
    Nov 2002
    I can upload either my master VDPROF file or break it down into separate encoder sets. You'll have to either change the paths or move the files.
    Dec 2005
    Canada
    @ racer-x
    The animated gif is output ok along with a zero byte file - same name as the gif but no extension.
    Any ideas?
  10. Member racer-x's Avatar
    Mar 2003
    Originally Posted by sambat View Post
    @ racer-x
    Any ideas?
    You can just delete the zero byte no extension file. It is just a temporary file. I haven't figured out how to auto delete that one yet.
  11. Member racer-x's Avatar
    Mar 2003
    I think it would be best to break it down into separate encoder sets, so people can pick and choose. It can quickly get cluttered with a large selection of encoders / muxers.
  12. Member racer-x's Avatar
    Mar 2003
    Nov 2002
    OK. Most of my encoders are in C:\Tools which is the recommended folder so that is where most of my paths will be directed to unless they need to be in program files.
    I suggested an option to load and unload vdprof files to Avery Lee but I don't know if he will put it in a future release or not. A right click option to select all encoder sets and remove would help. As it is now, you have to remove each encoder and encoder set one by one before adding a new vdprof file and if there is already a certain encoder in the vdprof file then Virtualdub will refuse to load the file.
    One user on the Virtualdub forum mentioned starting a wiki page with links to all versions of Virtualdub with all plugins, acm codecs, encoders and guides for using the external encoder, the curve editor and smart rendering. A lot more users would be interested if it was easier for them to use without having to search for everything on their own.
    Dec 2005
    Canada
    To be clear on the procedure to add a new profile where one already exists, I attempted to import 'MySettings.vdprof' and got the expected message that the profile 'mp4box' existed.
    I exported the existing .vdprof from VDub then slightly changed the encoder profile name of mp4box; deleted all existing settings and imported it back into VDub.
    Then I imported 'MySettings.vdprof' and it was integrated OK - granted the two profiles used slightly different paths, but it seems to work ok.
    Nov 2002
    That is why I mentioned it above. If it's just one encoder or encoder set that is causing it not to load then you can remove it but it's easier just to remove everything and load the vdprof that you want.
    My master vdprof file consists of 1,513 lines of text and has just about any encoder set you'd want. WMV is not possible although I was able to get some WMA files to work. I'll go ahead and upload the master vdprof for anyone who is interested and try and create separate encoder sets.
    Looking at the vdprof file and both my 32-bit and 64-bit versions of Virtualdub, I see they are both seeing my 64-bit encoders which isn't a problem for me but it could be for XP users or owners of 32-bit only versions of Windows. I'm going to have to mention this to Avery and see what he can do about it. It would be nice if every time you closed Virtualdub that it would close the vdprof file and force you to load it when you open Virtualdub but also give you the option of selecting a default vdprof file that it would automatically open.
    I'll hold off uploading it until I can get it all figured out unless someone wants it the way it is and change the paths. Eventually, I'd like to see a sticky thread with 32-bit and 64-bit versions of Virtualdub with input plug-ins, filters, acm codecs, ffmpeg and command line encoders with links to guides for all the new features.
  16. how to use mencoder as external encoder of virtualdub?
    this is my settings below
    audio:
    -ovc frameno -of rawaudio -af volnorm -oac faac -faacopts br=32:mpeg=4:
    object=2 -srate 22050 - -o "%(tempaudiofile)"
    video:
    -nosound -of rawvideo -ofps %(fpsnum)/%(fpsden) -vf harddup,pp=md/lb,scale=%(width):%(height) -ovc x264 -ffourcc H264 -x264encopts crf=24:threads=2:bframes=2:level_idc=21:nopsnr:nos sim -af volnorm - -o "%(tempvideofile)"
    multiplexer:
    -add "%(tempvideofile)" -add "%(tempaudiofile)" "%(outputname)" -fps %(fps)
    But it don't work, and give some error message "Cannot seek backward in linear streams! Seek failed",
    I don't know how to solve this problem,please give me some help,thanks
    Nov 2002
    Type: Video encoder
    Program: G:\Hybrid\mencoder.exe (or where-ever your copy is located)
    Command Arguments:
    -demuxer rawvideo -rawvideo w=%(width):h=%(height):fps=%(fps) - -ovc x264 -x264encopts bitrate=3000 pass=1 nr=2000 -o %(outputname).mp4
    Output file name: %(outputname)Leave Blank
    Launch Parameters: Leave Interpret non-zero return code as error unticked. Tick the other three
    Video encoder: Mencoder
    Audio encoder: none
    Multiplexer: none
    File description: Mencoder x264
    File extension: mp4
  18. Member
    Nov 2002
    You're Welcome
  19. Originally Posted by DarrellS View Post
    ffmpeg can encode some types of WMV - wmv2, wma2
    Have you tried using it with this command line WMV encoder?
    http://alexzambelli.com/WMV/#WMCmd
    Nov 2002
    The problem with Windows Media is that it uses those .vbs files. A few of us tried but we couldn't get it working. Seems trying to mux with ffmpeg was a problem also
    I still have the wmaencode.exe and I have a couple of WMV and WMA vdprof files. I gave up on them over a year ago though. I'll upload the vdprof files...
  21. DECEASED
    Jun 2009
    Heaven
    "In theory", it should be possible to add stdin support to the misnamed AVS2ASF program.
    The problem of course, is find someone who wants to do the job
    http://forum.doom9.org/showthread.php?t=133173
  22. Member
    Nov 2002
    Well crap, I spent some time today with the encoder above trying to get it to work and then I figured out that myself and a couple of others had already been in that thread a year and a half ago trying to get vc1 to work. I figured all the geniuses over there could get something going but either MS has made it impossible or there is just zero interest. I think those were my final words. That I had no interest for myself but for others and also getting as many encoders as possible to work. There are a lot of command line encoders out there but not a whole lot of them support stdin.
  23. how to use mencoder as external encoder of virtualdub?
    Video part is solved,But Audio part still not OK?
    this is my setting below(audio part):
    - -demuxer rawaudio -af volnorm -oac faac -faacopts br=32:mpeg=4bject=2 -srate 22050 -o %(outputname).aac
    Please help me again!
  24. Member
    Nov 2002
    You have to create a audio encoder set and a multiplexer set.
    Change txt to vdprof and place file in your VDPROF folder. In Virtualdub, under Options > External Encoders > choose Import and select the Mencoder-264-aac-mp4.vdprof file.
    Nevermind. I can get audio to encode but I can't get it to mux. Media info reads the file as AVI with H264 video. I wouldn't bother with Mencoder myself. Someone else with Mencoder experience helped me getting the video to work. I would use x264 myself.
  25. Thanks Darrells again.
  26. @racer-x settings work well,but...
    how to change the bitrate that is:
    how to create two-pass encoding such as on the MeGUI how to create preset medium,slow,slower,very slow,placebo...
    also how to create (Nero AAC: NDAAC- HE) for 32,48,64 etc.
    Any help is appreciated...
  27. Member
    Nov 2002
    All of this is covered in the Guide in the Virtualdub Forum...
    http://forums.virtualdub.org/index.php?act=ST&f=3&t=18840&
    If you have had Nero on your PC, you may already have a copy of neroAacEnc.exe on your PC (I use a program called "Everything" to search for files in Windows 7). If not, you'll need to download it from Nero. It's free but you have to give them your email address.
    I believe the amount of bit rate depends on the preset and the crf value. You can use your own custom settings though. I have an encoder set for every preset except for placebo. Just create a new encoder (x264 medium) and copy your original x264 encoder, changing the preset and the crf value.
  28. Member
    Nov 2002
    The newest test build (1.10.5-test7) gives you the option to overwrite the existing profiles when loading a .vdprof file.
    Changes:
    (test-7) Added /portablealt:<file> switch for using multiple INI files.
    (test-7) Added option to overwrite existing profiles when loading a .vdprof file.
    PluginAPI: Added SSE4.2 detection.
    AVI: Fixed crash when exporting segments with no audio track.
    Script: Added filters.BeginUpdate/EndUpdate() in saved job scripts to force timeline to update when frame rate changing filters are added.
  29. many thanks for the answer but...
    Perhaps I did not explain...
    I already use external encoder with these settings
    I need vdprof for two passes (for example mkv)
    I do not know to do...
    i thought you or someone else creates vdprof script for two pass
    I'm using this: http://pastebin.com/index/k6BXn0Sx
    how to rewrite it for two pass?
