Results 1 to 21 of 21
    Sep 2014
    Sao Paulo - Brazil
    Hello Guys
    I am a newbie into restoration and I need to restore 100 VHS Tapes + 25 hi8 Tapes as soon as I can.
    Let's make a long story short. I live in an apartment and have few space left, so most of my stuff ( audio and video ) are ripped on HD. All my VHS were in my parents house and since they are moving to an apartment, I have to get my stuff out of there.
    My biggest concern are all my Tapes. I can live without it for sure, but they are important to me.
    I am a Ramones collector fan and most of the tapes are music related - bootleg stuff, backstage footage, footage with the band etc, sports action footage and family footage.
    I know quality is an issue and I will never get any close to a dvd quality - but I wish I could get as much quality as I can.
    In these first moment I just want to have it on HD to get ride of the tapes and latter I will think about editing.
    Right now I am cleaning all the tapes, most of then are dirty and mold. It's been at least 10 years I don't use any of them. I know some of them are lost forever but I will try to recover as much tapes as I can.
    I got a cleaning device to remove mold from the tapes ( unfortunately it's not a RTI tapecheck 490 but it does the job )
    I tried to use a brand new low level cheap VCR but some footage i tried had a lot of jitter, noise etc.
    I got a brand new, never used, in original box - JVC Hr-s9911u. ( the seller has another 2 left for sell ) and some good Monster Cables.
    Should I buy a TBC AVT-8710 or only the JVC ( with TBC/DNR ) will do the job ? I am a little lost at this point.
    I have a cheap capture card ( EZcap ) but it records on mpg-2 and I have to convert it to .mov to edit in Final Cut Pro X - so I am planning on get a Avermedia Extremecap U3 Hdmi. What would be the best capture setting to use ? ( 720 x 480 - 30 or 60p )
    Should I stick with Avermedia Extremecap or get a different capture card. It has to be USB because I am going to capture it on a PC Notebook and edit latter on a MAC. I can't capture it on my iMac.
    After I get all tapes on HD I will begin to edit it and have no problem how long it's going to take.
    Should I get any plugins , post process filter for Final Cut Pro X to help me correct any errors from the footage ?
    Any other hardwares are recommended ?
    I have never done that before and so I am little bit lost. Any help will be appreciated.
    I will post the restoration progress after I clean all the tapes.
    PS - I am sorry for my English
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    How are you planning to connect that HDMI capture device to your HR-S9911U?
    Sep 2014
    Sao Paulo - Brazil
    The capture device has a composite video in ( S-Video + LR audio )
  4. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    I recommend a Canopus ADVC box. Then just import directly to the software of your choice using the FireWire cable.
    Sep 2014
    Sao Paulo - Brazil
    Unfortunatly I will have to capture it on a PC that doesn't have firewire port, only USB 3.0
  6. Member Cornucopia's Avatar
    DV and HDV only work correctly through Firewire, not USB (any version).
  7. Originally Posted by saulera View Post
    Going by the specs, the JVC shouldn't need an external TBC. At least experiment without it before deciding to purchase.
    The extremecap claims to be mac compatible, but that may only be for game capture. I would find some way to capture directly to mac (Elgato Video capture or Blackmagic Intensity for example) to some suitable flavor of ProRes. This avoids a re-encoding step that FCPX is likely to do, gives you good quality iframe material to edit with, and avoids the issue of incompatible mac/pc hard drive formats.
    (edit: double check whether FCPX will recognize the EZCap.)
    Match your source. Probably 720x480 29.97i (aka 30i, aka 59.94i)
    Last edited by smrpix; 8th Sep 2014 at 07:12. Reason: clarification of Mac capture devices
    Sep 2014
    Sao Paulo - Brazil
    BTW I can capture it from a macbook pro with firewiere 800 port. Thanks for the advice.
  9. Originally Posted by saulera View Post
    Nope, won't work. Must be FW400 directly or FW800->Thunderbolt.
    But I also recommend you investigate the process I described above. SD ProRes capture has quality advantages and similar bitrates to DV (and I am far from a ProRes fanboy.)
  10. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    I guess I misunderstood the original objective. I thought he was going to capture VHS from a standard VCR which would use the composit inputs of the Canopus, and also Digital8 tapes which would use FireWire. I have a cable that accepts FW400 input and connects to a FW800 on the other connector. I haven't done this for quite some time, it worked perfectly for me.
  11. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    AVerMedia indicates it comes with a dongle for component input, not composite or S-Video.
  12. Originally Posted by crjackson View Post
    I believe he said Hi8, not digital 8 so it's all analog on the source side. That's why I bypassed DV as an option -- though it's certainly viable.
    Interesting, if the canopus does not require machine control that might increase the likelihood of FW400->FW800 working. Hadn't considered that.
  13. Member crjackson's Avatar
    May 2002
    Charlotte, NC
    Yes you are correct. He did say Hi8. My old Handycam does both and I've forgotten that Hi8 is different, I never use that. mea culpa ...
    I plug the Handycam's FW400 into the ADVC-100 FW400 input, then, using a FW400>FW800 cable, I plug ADVC into my Mac's FW400 port and import to FCPX. I've not noticed any problems, but I haven't tried camera transport control either. I'll test that out next time I have a project.
    Sep 2014
    Sao Paulo - Brazil
    Sorry, my mistake
    Sep 2014
    Sao Paulo - Brazil
    I am going to use a Digital8 camcorder throught firewire port ( even using Hi8 Tapes )
    Sep 2014
    Sao Paulo - Brazil
    Should I go with ADVC-100 - 110 or 300 ?
    I will receive the JVC Hr-s9911u tomorrow but I still have a long process for cleaning all the tapes before convert it.
    I am going to test the images on JVC and see if I need the TBC. In the meantime while I clean up the tapes I have some time do to some tests before final convertion.
  17. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    There's no point getting a Digital8 camcorder that supports analog conversion and an ADVC-100/110.
  18. Member
    Sep 2014
    Sao Paulo - Brazil
    I have only 20 Hi8 tapes.
    I am going to use the ADVC-100/110 withthe VHS Tapes ( + 100 ).
    At least, that's what I am planning.
  19. Originally Posted by saulera View Post
    What vaporeon is saying is that if you have a digital8 camera you can use that as a pass through device for digitizing the VHS material, and the ADVC is redundant.
    Sep 2014
    Sao Paulo - Brazil
    Sorry, I didn't understand what vaporeon was trying to tell me. I have a Sony TRV530 that just bought 2 weeks ago because my old Hi8 has gone a long time ago and I needed any camera to playback the tapes. The TRV530 was the best deal I could get. I didn't know was possible to use as pass through device. Last night I bought the ADVC-110 - now it's too late.
    What would be my best option ? Use the ADVC-110 or the camcorder ?
  21. Originally Posted by saulera View Post
    Try both. I would bet the tbc in the JVC deck is doing most of the work and you won't see much difference.
