Results 1 to 11 of 11
    Jul 2014
    Edinburgh
    There's a set of AVIs I would like to eventually convert to MP4 format for watching on small-display devices. But for now I am getting to grips with the different codecs and formats, and have simply been providing the video with a new container using ffmpeg or my new best 'friend' Xmedia Recode'.
    I have three pretty similar AVI files from ripped DVD (say A, B and C) that I would like re-container (i.e. copy acodec and vcodec). It works for one format (file C), but not the other two, in the sense that mediaplayer such as MPC-HC only plays the audio and not the video of file A.mp4 or B.mp4. I am trying to better understand link between content and container. What is the reason behind the video A and B not being compatible with their new MP4 container?
    Many thanks for any feedback.
    A.avi:
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    File size                                : 174 MiB
    Duration                                 : 23mn 45s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 1 026 Kbps
    Writing application                      : Nandub v1.0rc2
    Writing library                          : Nandub build 1852/release
    Video
    Format                                   : MPEG-4 Visual
    Format settings, BVOP                    : No
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (MPEG)
    Codec ID                                 : XVID
    Codec ID/Hint                            : XviD
    Duration                                 : 23mn 45s
    Bit rate                                 : 898 Kbps
    Width                                    : 512 pixels
    Height                                   : 384 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.190
    Stream size                              : 153 MiB (88%)
    B.avi:
    Format                                   : AVI
    File size                                : 233 MiB
    Duration                                 : 22mn 45s
    Overall bit rate                         : 1 431 Kbps
    Writing library                          : Nandub build 1853/release
    Video
    Format profile                           : Simple@L3
    Format settings, Matrix                  : Default (H.263)
    Codec ID                                 : XVID
    Duration                                 : 22mn 45s
    Bit rate                                 : 1 289 Kbps
    Width                                    : 576 pixels
    Height                                   : 432 pixels
    Bits/(Pixel*Frame)                       : 0.216
    Stream size                              : 210 MiB (90%)
    Writing library                          : XviD 0.0.12 (UTC 2003-06-11)
    C.avi:
    Format                                   : AVI
    File size                                : 233 MiB
    Duration                                 : 22mn 58s
    Overall bit rate                         : 1 417 Kbps
    Writing application                      : VirtualDubMod 1.5.4.1 (build 2178/release)
    Writing library                          : VirtualDubMod build 2178/release
    Video
    Format profile                           : Advanced Simple@L5
    Format settings, BVOP                    : 1
    Format settings, Matrix                  : Custom
    Codec ID                                 : XVID
    Duration                                 : 22mn 58s
    Bit rate                                 : 1 271 Kbps
    Width                                    : 576 pixels
    Height                                   : 432 pixels
    Bits/(Pixel*Frame)                       : 0.213
    Stream size                              : 209 MiB (90%)
    Writing library                          : XviD 1.0.2 (UTC 2004-08-29)
    A.mp4:
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 173 MiB
    Duration                                 : 23mn 45s
    Overall bit rate                         : 1 018 Kbps
    Encoded date                             : UTC 2014-09-03 20:55:47
    Tagged date                              : UTC 2014-09-03 20:55:47
    Writing application                      : Lavf55.55.100
    Video
    Codec ID                                 : 20
    Duration                                 : 23mn 45s
    Bit rate mode                            : Constant
    Bit rate                                 : 898 Kbps
    Width                                    : 512 pixels
    Height                                   : 384 pixels
    Frame rate mode                          : Constant
    C.mp4:
    Codec ID                                 : isom
    File size                                : 230 MiB
    Duration                                 : 22mn 58s
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 1 403 Kbps
    Video
    Format settings, BVOP                    : Yes
    Codec ID                                 : 20
    Duration                                 : 22mn 58s
    Width                                    : 576 pixels
    Height                                   : 432 pixels
    Stream size                              : 209 MiB (91%)
    Jul 2014
    Edinburgh
    ...and file B.mp4:
    Codec ID                                 : isom
    File size                                : 231 MiB
    Duration                                 : 22mn 45s
    Overall bit rate                         : 1 421 Kbps
    Video
    Codec ID                                 : 20
    Duration                                 : 22mn 45s
    Width                                    : 576 pixels
    Height                                   : 432 pixels
    Stream size                              : 210 MiB (91%)
  3. I don't see anything in the video that looks problematic. What about audio codecs?
    Jul 2014
    Edinburgh
    I can copy acodec or convert mp3 to aac, but this does not affect playback or solve the problem with A and B.mp4. Thanks Jagabo.
    Jul 2014
    Edinburgh
    Will install Mpeg4Modifier and let you know. Cheers.
  6. Sorry, I was wrong about MediaInfo not showing packed bitream. It does list the feature if it is used in the file. So that's probably not your problem.
    Jul 2014
    Edinburgh
    No packed bitstream for all files, I'm afraid...
    A.avi:
    Packed bitstream:  No
    QPel:              No
    GMC:               No
    Interlaced:        No
    Aspect ratio:      Square pixels
    Quant type:        MPEG
    FourCC:            XVID
    I-VOPs: 484 (1.42%)
    P-VOPs: 33692 (98.58%)
    B-VOPs: 0 (0.00%)
    S-VOPs: 0 (0.00%)
    N-VOPs: 0 (0.00%)
    B.avi:
    QPel:              No
    GMC:               No
    Interlaced:        No
    Quant type:        H.263
    FourCC:            XVID
    User data:         XviD0012
    I-VOPs: 254 (0.78%)
    P-VOPs: 32495 (99.22%)
    B-VOPs: 0 (0.00%)
    S-VOPs: 0 (0.00%)
    N-VOPs: 0 (0.00%)
    C.avi:
    QPel:              No
    GMC:               No
    Interlaced:        No
    Quant type:        MPEG Custom
    FourCC:            XVID
    User data:         XviD0036
    Custom intra matrix:
          8  16  20  23  27  30  32  34
         16  16  23  24  29  31  34  38
         20  23  27  28  30  35  38  40
         23  24  28  29  35  39  40  44
         27  29  30  35  39  42  45  50
         30  31  35  39  42  46  54  59
         32  34  38  40  45  54  62  72
         34  38  40  44  50  59  72  84
    Custom inter matrix:
         17  19  21  23  25  27  29  31
         19  21  23  25  27  28  29  33
         21  23  25  27  29  30  32  37
         23  25  27  30  31  34  40  45
         25  27  29  31  38  46  54  60
         27  28  30  34  46  58  72  74
         29  29  32  40  54  72  90 100
         31  33  37  45  60  74 100 124
    I-VOPs: 321 (0.97%)
    P-VOPs: 16491 (49.91%)
    B-VOPs: 16228 (49.12%)
    S-VOPs: 0 (0.00%)
    N-VOPs: 0 (0.00%)
    Max consecutive B-VOPs:   1
    Is a B-VOP value of zero not compatible with mp4 or its value not copied using ffmpeg?
  8. If you told me one file didn't play after muxing into MP4 I would have guessed C. Some old devices didn't support B frames and custom matrices. And C is the highest Profile But that's the file that does play. The other two are simpler and shouldn't have problems. All I can suggest is you try reencoding with and without the different settings until you find what's causing the problem for your device.
  9. All I can suggest is trying a different program.
    MyMP4BoxGUI should do it.
    If you open an AVI to remux it, it'll only display the video stream in the GUI which gives the impression the audio needs to be added separately, but that's not the case. You should just be able to add an AVI and re-mux.
    MP4Box can be a bit finicky sometimes. It doesn't seem to like AVIs where the audio stream contains junk data (some AVI muxing programs add it) and it'll start muxing and then quit for no apparent reason. It's still be worth a shot though.
    I use Video To Video Converter for "odd job" remuxing quite a bit. When you add a file for conversion, it'll open a window and ask you to pick a conversion preset. "Direct Stream Copy" (the last on the video profiles list) would be the one to try. All you need to do is select it, then choose your desired output container on the right. It adds the job to the conversion list, but it just copies the video and audio, despite the need to click on "convert".
    You can open a bunch of files or a folder of them for batch conversion. It's managed to remux files for me quite a few times the usual methods have failed. It probably uses ffmpeg for a lot of the work, but you never know.....
    Jul 2014
    Edinburgh
    Many thanks for the suggestions jagabo & hello_hello.
    Yes, it's peculiar it's both the A and B MP4 that do not play whilst C is fine. I was not able to find the exact cause.
    So what worked?
    MyMP4BoxGUI was able to generate a new MP4 container that played in MPC-HC but not in WMP. To play an MP4 in a range of mediaplayers I needed to transcode.
    Also thanks for the Video2video converter suggestion. A great new tool for my box!
  11. It still seems odd, having to transcode.
    Did you try any of MyMp4BoxGUI's options? There's a couple for making MP4s "apple friendly" and a few others under options/advanced. Maybe you could try one of these?
    -isma: converts file to ISMA 1.0 specification. This is extremely useful since most MPEG-4 players only understand ISMA-like content. All systems information and tracks numbering are rewritten to comply to the specification.
    WARNING: some media tracks may be removed.
    -3gp : converts to 3GPP specification. This will remove all MPEG-4 Systems information, leaving only the audio/video/text media tracks supported by 3GPP. This option is always turned on when the file extension is ’3gp’ or ’3g2′.
    MeGUI has an MP4 muxer under it's Tools menu. I didn't mention it as it also uses MP4Box for the work, but it offers the ability to select device compatibility. For example if you select "iphone" it adds the following to the commandline: -ipod -brand M4VP:1
    I couldn't seem to find it in MyMP4Box's command line options.
    I don't use MP4 but I remuxed a few AVIs and couldn't output one MPC-HC or WMP wouldn't play, but I didn't try any other devices. The version of WMP I have is the one which comes with XP. I never use it, but it's so old it doesn't even recognise the MP4 file type and asks if you want to open an "unknown file extension". It still plays the AVIs I remuxed though (with the Haali media splitter's help).
