Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 10 of 10
  1. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Hello!
    I have this PAL DVD that is an official release but it has what I can only describe as weird / odd interlacing artifacts. I'd love to convert it to an x264 / AC-3 MKV file but I have no clue how to deinterlace it.
    I uploaded a sample to MediaFire. This was cut out of one of the VOB files using VideoReDo and then saved as an *.mpg file. VideoReDo doesn't do any re-encoding (other than at the edit points which in this case would be the first few and last few frames).
    Here's the file: CLICK HERE
    Note that this is a ZIP file and the MPG file is inside of it.
    - John "FulciLives" Coleman
  2. It's not interlace, just residual combing because the fields aren't aligned properly
    I would use vinverse() on it
  3. I agree with it being caused by the fields not being aligned properly. I usually handle this kind of thing differently, though:
    QTGMC()#at whatever settings or presets you like
    SelectEven()#or SelectOdd, whichever looks better
    Admittedly, Vinverse will be a helluva lot faster.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Subtitles...... SUBTITLES!!!!!!
    LOL!!!
    Yeah I watched it in VLC and MPCHC and it did not seem to need de-interlacing.
    HOLY CRAP DUDE!!!
    I have not seen you post in like eons!!!!
    WAAAZ UP!!!!!!!!
  5. Member FulciLives's Avatar
    May 2003
    Thanks guys I'll try playing around with what you suggested. It's really annoying because you can tell the picture looks really nice but the fields being aligned improperly really ruins it and the shame is that almost every DVD that this company releases has the exact same issue which makes it maddening since they otherwise appear to be nice remasters and despite being an Italian DVD label they often put on English of some sort (be it a dub track or subtitles).
    And yes I barely post these days. I pretty much learned all that I need to know in the past and these days I mostly deal with progressive HD video and there really isn't much to that lol so I rarely need questions answered but thank god for this place (and people like manono) still being around!
  6. Member FulciLives's Avatar
    May 2003
    I figured out how to use Vinverse and it seems to have made an improvement.
    I tried QTGMC but I honestly don't get how to use it. I'm pretty sure I put all the needed *.dll files in the correct spot but then it says to do this and this confused me:
    Install AviSynth and copy the plugins from the plugin package to the correct locations. Then to use QTGMC, write a script like this:
    YourSource("yourfile") # DGDecode_mpeg2source, FFVideoSource, AviSource, whatever your source requires
    QTGMC( Preset="Slow" )
    SelectEven() # Add this line to keep original frame rate, leave it out for smoother doubled frame rate
    Save this script with an ".avs" extension. You can now use it as an AVI source for encoding.
    I don't understand ... I'm used to loading a *.dll file and then just using the function ???
  7. I'm seeing video that has been dup-field deinteralced. I'd use something like:
    PointResize(width, height/2)
    nnedi3_rpow2(2, cshift="Spline64Resize", fwidth=width, fheight=height*2)
    Maybe with a little sharpening afterward.
  8. Originally Posted by jagabo View Post
    I like this result the best
    The top & bottom borders are better, overall lines are cleaner when you zoom in
    It's just resizing vertically down and up, but it works here
    If it was just a field misalignment, then theoretically you could separate fields, and to decimal / subpixel shifts
  9. Member FulciLives's Avatar
    May 2003
    I tried the PointResize thing along with nnedi3_rpow2 and it does seem to look better than when I simply used vinverse so thanks a lot!
    I'm encoding it now so after it's done I'll get back to this thread to report how well it turned out but I think it's going to be just fine.
  10. Member FulciLives's Avatar
    May 2003
    Here's a link to the fixed clip. It's a MKV with x264 video and AC-3 audio. Again it's in a ZIP file.
    http://www.mediafire.com/download/94wpbep83p1ffes/VTS_03_2_fixed.zip
    Encoding was done using RipBot264 and tweaking it's AviSynth script.
    Thanks guys!
