  1. Title says it all. I'm thinking of resorting to mainconcept AVC export.
    MeGUI cmd:
    --bitrate 10000 --preset veryslow --tune animation --bluray-compat --vbv-maxrate 10000 --vbv-bufsize 10000 --level 4.1 --keyint 23.976 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 --crf=10
    Doesn't jitter on my PC oddly. If anyone has any ideas, please let me know. Video re-compresed by architect played fine.
    (The video sort of speeds up and moves up and down every second)
  2. Originally Posted by supagui1 View Post
    MeGUI cmd:
    What do you mean exactly by "jitter"? up and down do you mean vertically up & down ? or the speed goes up and down?
    What resolution is this for ?
    These won't help for that problem, but it should be --keyint 24, and fix the commandline: you have both --bitrate 1000 and --crf 10 specified
  3. What do you mean exactly by "jitter"? up and down do you mean vertically up & down ? or the speed goes up and down?
    Sorry for not specifying - the video moves vertically up and down quickly, and the speed is also inconsistent. Basically the video is entirely glitched.
    This is for a 1080p blu ray.
  4. What is the source and how are you feeding it to x264 ?
    Can you post the log file or console text of the encode ? were there any errors ?
  5. Originally Posted by poisondeathray View Post
    [Information] Log
    -[Information] Versions
    --[Information] [9/2/2014 8:25:59 PM] MeGUI: 2507
    --[Information] [9/2/2014 8:25:59 PM] Operating System: Windows 7 Premium Edition x64 SP1 (6.1.65536.7601)
    --[Information] [9/2/2014 8:25:59 PM] .Net Framework: 2.0.50727.5420
    --[Information] [9/2/2014 8:25:59 PM] .Net Framework: 4.0.30319
    --[Information] [9/2/2014 8:25:59 PM] AviSynth: 2.5.5.0 (01-09-2004)
    --[Information] [9/2/2014 8:25:59 PM] AvisynthWrapper:  (02-01-2009)
    --[Information] [9/2/2014 8:25:59 PM] Haali Matroska Splitter: not installed
    --[Information] [9/2/2014 8:25:59 PM] Haali DSS2: not installed
    --[Information] [9/2/2014 8:25:59 PM] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
    --[Information] [9/2/2014 8:25:59 PM] LinqBridge: 1.0.0.0 (28-05-2009)
    --[Information] [9/2/2014 8:25:59 PM] MediaInfo: 0.7.69.0 (24-04-2014)
    --[Information] [9/2/2014 8:25:59 PM] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
    --[Information] [9/2/2014 8:25:59 PM] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
    --[Information] [9/2/2014 8:25:59 PM] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
    --[Information] [9/2/2014 8:25:59 PM] 7z: 9.20 (18-11-2010)
    -[Information] Update detection
    --[Information] [9/2/2014 8:25:59 PM] Using cached update config and server: http://megui.org/auto/stable/
    --[Information] [9/2/2014 8:25:59 PM] No package requires an update
    -[Information] Log for job1 (video, vid.avs -> vid.264)
    --[Information] [9/2/2014 8:36:13 PM] Started handling job
    --[Information] [9/2/2014 8:36:13 PM] Preprocessing
    --[Information] [9/2/2014 8:36:13 PM] Avisynth input script
    ---[NoImage] DirectShowSource("K:\vid.mp4", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    ---[NoImage] #deinterlace
    ---[NoImage] #crop
    ---[NoImage] #resize
    ---[NoImage] #denoise
    --[Information] [9/2/2014 8:36:14 PM] resolution: 1920x1080
    --[Information] [9/2/2014 8:36:14 PM] frame rate: 24000/1001
    --[Information] [9/2/2014 8:36:14 PM] aspect ratio: 16:9 (1.778)
    --[Information] [9/2/2014 8:36:14 PM] custom command line: --bitrate 10000 --preset veryslow --tune animation --bluray-compat --vbv-maxrate 10000 --vbv-bufsize 10000 --level 4.1 --keyint 24 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1
    --[Information] [9/2/2014 8:36:14 PM] Job commandline: "G:\MeGUI_2507_x86\tools\x264\avs4x264mod.exe" --level 4.1 --bluray-compat --keyint 23 --weightp 2 --slices 4 --vbv-bufsize 10000 --vbv-maxrate 10000 --bitrate 10000 --preset veryslow --tune animation --open-gop --pass 1 --sar 1:1 --output "K:\vid.264" "K:\vid.avs"
    --[Information] [9/2/2014 8:36:16 PM] Process started
    --[Information] [9/2/2014 8:36:16 PM] Standard output stream
    ---[Information] [9/2/2014 8:46:16 PM] avs [info]: AviSynth 2.55, build:Sep  1 2004 [16:49:03]
    ---[Information] [9/2/2014 8:46:16 PM] avs [info]: Video colorspace: YV12
    ---[Information] [9/2/2014 8:46:16 PM] avs [info]: Video resolution: 1920x1080
    ---[Information] [9/2/2014 8:46:16 PM] avs [info]: Video framerate: 24000/1001
    ---[Information] [9/2/2014 8:46:17 PM] avs [info]: Video framecount: 29525
    ---[Information] [9/2/2014 8:46:17 PM] avs4x264 [info]: "x264_64" - --level 4.1 --bluray-compat --keyint 23 --weightp 2 --slices 4 --vbv-bufsize 10000 --vbv-maxrate 10000 --bitrate 10000 --preset veryslow --tune animation --open-gop --pass 1 --sar 1:1 --output "K:\vid.264"  --frames 29525 --fps 24000/1001 --input-res 1920x1080 --input-csp i420
    --[Information] [9/2/2014 8:36:16 PM] Standard error stream
    ---[Information] [9/2/2014 8:36:18 PM] raw [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr)
    ---[Information] [9/2/2014 8:36:18 PM] x264 [info]: using SAR=1/1
    ---[Information] [9/2/2014 8:36:18 PM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX XOP FMA4 FMA3 LZCNT BMI1
    ---[Information] [9/2/2014 8:36:18 PM] x264 [info]: profile Main, level 4.1
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: frame I:1545  Avg QP: 8.67  size:371923
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: frame P:9991  Avg QP:13.31  size: 62123
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: frame B:17989 Avg QP:16.72  size:  8681
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: consecutive B-frames: 10.9% 20.1% 10.3% 58.7%
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: mb I  I16..4: 33.2%  0.0% 66.8%
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: mb P  I16..4: 14.7%  0.0%  0.0%  P16..4: 47.3%  0.0%  0.0%  0.0%  0.0%    skip:38.1%
    ---[Information] [9/2/2014 8:46:16 PM] x264 [info]: mb B  I16..4:  1.4%  0.0%  0.0%  B16..8: 10.0%  0.0%  0.0%  direct: 8.5%  skip:80.1%  L0:42.4% L1:48.3% BI: 9.3%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: direct mvs  spatial:99.9% temporal:0.1%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: coded y,uvDC,uvAC intra: 54.8% 56.2% 36.7% inter: 10.0% 16.4% 2.8%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: i16 v,h,dc,p: 52% 22% 22%  5%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 23% 16%  7%  6%  5%  6%  5%  8%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: i8c dc,h,v,p: 55% 22% 19%  4%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: Weighted P-Frames: Y:1.2% UV:0.9%
    ---[Information] [9/2/2014 8:46:17 PM] x264 [info]: kb/s:8779.68
    ---[Information] [9/2/2014 8:46:17 PM] encoded 29525 frames, 49.34 fps, 8779.68 kb/s
    --[Information] [9/2/2014 8:46:17 PM] Final statistics
    ---[Information] [9/2/2014 8:46:17 PM] Constant Quality Mode: Quality 23 computed...
    ---[Information] [9/2/2014 8:46:17 PM] Video Bitrate Obtained (approximate): 8779 kbit/s
    --[Information] [9/2/2014 8:46:17 PM] MediaInfo
    ---[Information] [9/2/2014 8:46:17 PM] File: K:\vid.264
    ---[Information] General
    ----[Information] Format: AVC
    ----[Information] FormatString: AVC
    ----[Information] FileSize: 1351454755
    ----[Information] PlayTime:
    ---[Information] Video
    ----[Information] ID:
    ----[Information] StreamOrder:
    ----[Information] Width: 1920
    ----[Information] Height: 1080
    ----[Information] FrameCount:
    ----[Information] FrameRate: 23.976
    ----[Information] FrameRateOriginal:
    ----[Information] FrameRateMode:
    ----[Information] ScanType: Progressive
    ----[Information] Codec: AVC
    ----[Information] CodecString: AVC
    ----[Information] Bits Depth: 8
    ----[Information] AspectRatio: 1.778
    ----[Information] AspectRatioString: 16:9
    ----[Information] Delay:
    ----[Information] Title:
    ----[Information] Language:
    ----[Information] LanguageString:
    ----[Information] Default:
    ----[Information] DefaultString:
    ----[Information] Forced:
    ----[Information] ForcedString:
    --[Information] [9/2/2014 8:46:18 PM] Postprocessing
    ---[Information] [9/2/2014 8:46:18 PM] Deleting intermediate files
    --[Information] [9/2/2014 8:46:18 PM] Job completed
    Looking back at the video, stuttering would probably be a better word for it.
