  1. I having issues with my HD-PVR 2. I keep getting framedrops anywhere from 7 to 100+. I never had framedrops before. I thought maybe it was my PC or HD-PVR 2. Tried it on a brand new i7 PC same thing and a new HD-PVR, It still happening.
    Anyone know why I am having these framedrops?
  2. Member DB83's Avatar
    Jul 2007
    It may assist if you expand on your setup.
    Are you capping from a tv-receiver or a game console ?. Is there a hdmi-splitter or even a hdcp_stripper in the chain ?. Have you changed the cables ?
  3. Originally Posted by DB83 View Post
    Are you capping from a tv-receiver or a game console ?. Is there a hdmi-splitter in the chain ?. Have you changed the cables ?
    Source: Gaming console
    HDMI Splitter: Yes (had the same one for years)
    Cables: all the same, No change.
    Everything was fine until about a month ago.
  4. Member DB83's Avatar
    Jul 2007
    Well since neither the splitter nor the cables have been changed I would look at those.
    In fact, I would have checked the cable first. Also try a cap direct from the console to the pvr ie take the splitter out of the chain (unless, of course, you are using that also as a stripper and it is required)
    I expect you know the prime reason for dropped frames - the HDD can not keep up with the stream but since you have effectively changed the HDD that can be ruled out.
  5. Originally Posted by DB83 View Post
    I doubt it's the drives, since I have it running straight to a SSD. I will look at the cables. I also have a elgato HD60 and it's not listing any kind of framedrops with exactly same cables & splitters. Dunno, why I find this issue popping up on HD-PVR 2 confusing.
    *Update*
    Small update I changed some cables around it went from the usually 7 frames dropped to 4 frames dropped.
  6. It seems frames only drop when recording from PS3(HDMI or Component). I just recorded 2 hours of footage from PS4 no framedrops. Maybe the recent system update screwed something up with output signals.
