Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 64
  1. Hi cats,
    I would like do an avisynth script that, for all mp4 in various format that I can put, it output alwais a stream @ 25fps interlaced.
    Fo example, if the opened file is a 25fps it don't have do to nothing, but if the opened file is 50fps it have to convert it to 25 fps interlaced
    The output have to be alwais 25fps interlaced for all
    If for example, the input file i a 100 fps, it have to output a stream of 25fps interlaced
    is it possible that? thanks
    Sep 2012
    Australia
    Yes, there are methods, but any kind of conversion has consequences and as always there's no BEST way to do it other than not doing it in the first place.
  3. Avisynth script would be created inside batch script, I do it that way, but it could get complicated ...
    this one creates letterboxed DV avi by VirtualDub with free Cedocida codec by dropping 60p mp4 HD onto batch script:
    SET path_destination=%~dp0OUTPUT
    SET path_temp=%~dp0temp
    SET name=%~n1
    SET filename_input=%~d1%~p1%~n1%~x1
    SET destination_adr=%path_destination%\%name%
    SET temp_adr=%path_temp%\%name%\%name%
    SET temp_folder=%path_temp%\%name%
    SET destination_folder=%path_destination%
    if not exist "%destination_folder%" ( MD "%destination_folder%" )
    if not exist "%temp_folder%" ( MD "%temp_folder%" )
    echo emptying temp folder if folder exists: %temp_folder%\
    if exist "%temp_folder%" ( DEL /F /Q "%temp_folder%"\*.* )
    SET virtualdub="%~dp0tools\VirtualDub\vdub.exe"
    SET mediainfo=%~dp0tools\Mediainfo\MediaInfo.exe
    SET get_videoinfo="%~dp0tools\subroutines\get_videoinfo.BAT"
    SET ffms2_dll="%~dp0tools\plugins\ffms2.dll"
    SET ffms2_avsi="%~dp0tools\plugins\FFMS2.avsi"
    SET encode_DV_by_cedocida_vcf="%~dp0tools\plugins\encode_DV_by_cedocida.vcf"
    SET ColorMatrix="%~dp0tools\plugins\ColorMatrix.dll"
    REM ************************** MediaInfo for dropped video **************************
    REM mediainfo subroutine reads %filename_input%
    call %get_videoinfo%
    echo video found: %format%  %w%x%h%
    echo frame rate: %fps%
    echo field order: %field_order%
    echo aspect ratio: %ar%
    REM *************************** Creating Avisynth script ******************************
    echo+
    echo creating avisynth script: %name%.avs
    echo Import(%ffms2_avsi%)                                    > "%temp_adr%.avs"
    echo LoadPlugin(%ffms2_dll%)                                >> "%temp_adr%.avs"
    echo LoadPlugin(%ColorMatrix%)                              >> "%temp_adr%.avs"
    echo ffmpegsource2("%filename_input%", atrack=1)            >> "%temp_adr%.avs"
    echo spline16resize(720,366)                                >> "%temp_adr%.avs"
    echo Blur(0,0.5) #vertical blur 0.5 to 1.5                  >> "%temp_adr%.avs"
    echo AddBorders(0,57,0,57)                                  >> "%temp_adr%.avs"
    echo ConvertFPS("ntsc_double")                              >> "%temp_adr%.avs"
    echo ColorMatrix(mode="Rec.709->Rec.601", clamp=0)          >> "%temp_adr%.avs"
    echo assumeframebased().assumebff().SeparateFields().SelectEvery(4,0,3).weave()  >> "%temp_adr%.avs"
    REM *************************** encoding with Virtual Dub ******************************
    echo.
    type "%temp_adr%.avs"
    echo.
    echo command line:
    echo vdub.exe /c /s "encode_DV_by_cedocida.vcf" /p "%name%.avs","%name%.avi" /r /h /x
    echo.
    echo VirtualDub is encoding: %~n1.avi ...
    %virtualdub% /c /s %encode_DV_by_cedocida_vcf% /p "%temp_adr%.avs","%destination_adr%.avi" /r /h /x
    pause
    it is just taken out of even more larger script, so some things might be missing, point is that you'd have to add lines while creating avisynth script depending on frame rate etc.
    for example adding line:
    if %fps%==100 echo select even() >> "%temp_adr%.avs"
    etc., etc, there would be much more conditions, depending on the source, video might be anamorph, where script is a bit different etc., it could go out of hand, better is to check the source (mediainfo or ffprobe) andthen run separate function or batch file that sorts only that particular case, like HD mp4 , 100fps ...
  4. Originally Posted by marcorocchini View Post
    Where are you going to get a 100fps clip ?
    Aren't you only dealing with 25fps interlaced , and 50p source ?
    What would you do with 100fps ? Throw away 1/2 the frames then make it 25fps interlaced ?
    What if you had 66.586766 fps ? How would you do the division ?
    Here is the simple "if then" in avisynth for those two cases of 25fps interlaced, 50p. You will get wrong result with anything else:
    src=last
    src.framerate<26 ? src : src.AssumeTFF().SeparateFields().SelectEvery(4, 0, 3).Weave()
  5. Where are you going to get a 100fps clip ?
    OHH I'm a cat
    I shot my cat with a small gopro hero3+ for cats
  6. Originally Posted by poisondeathray View Post
    src=last
    Oh my *** Name:  oh-my-word.jpg
  7. src=last
  8. WOW!
    SORRY POISON MY CATS HAVE ANOTHER QUESTION:
    THIS IS THE SCRIPT THAT DO THIS: LOAD A MP4 FILE THAT IF SOURCE IS > 25FPS --> NORMALIZE FPS TO 25FPS. IF SOURCE IS 25FPS don't touch nothing:
    FFVideoSource("c:\GOPR1225.mp4")
    src=last
    ChangeFPS(25)
    AssumeFPS(25)
    ConvertToYUY2(interlaced=true)
    Now, if possibile, I would like do exaxtly the same with resolutions that Are Not 720x576: if the source file is a resolution more or lower 720X576 ----> the script have to apply the IResize(7520,576):
    IResize(720,576)
    function IResize(clip Clip, int NewWidth, int NewHeight) {
    Clip
    SeparateFields()
    Shift=(GetParity() ? -0.25 : 0.25) * (Height()/Float(NewHeight/2)-1.0)
    E = SelectEven().Spline36resize(NewWidth, NewHeight/2, 0, Shift)
    O = SelectOdd( ).Spline36resize(NewWidth, NewHeight/2, 0, -Shift)
    Ec = SelectEven( ).Spline36resize(NewWidth, NewHeight/2, 0, 2*Shift)
    Oc = SelectOdd( ).Spline36resize(NewWidth, NewHeight/2, 0, -2*shift)
    Interleave(E, O)
    IsYV12() ? MergeChroma(Interleave(Ec, Oc)) : Last
    Weave()
    AssumeTFF()
    SeparateFields()
    Ev=SelectEven().sharpen(0.20)
    Od=SelectOdd().sharpen(0.20)
    Interleave(Ev,Od)
    Weave()
    Assumetff().SeparateFields().SelectEvery(4, 0, 3).Weave()
    so the script become something like this (?):
    ColorMatrix(mode="Rec.709->Rec.601")
    IResize(720,576)
    Clip
    SeparateFields()
    Interleave(E, O)
    Weave()
    AssumeTFF()
    SeparateFields()
    Interleave(Ev,Od)
    Weave()
    src=last
    ChangeFPS(25)
    AssumeFPS(25)
    I wonder: can modify the script so that the IResize acts only for resolutions different from 720x576?
    And can I modify the script so that the colormatrix become from bt709tobt601 only if the source have is at a resolution that are more 720x576 (not if the the flags of a mp4 is specifically bt709, but only if the resolution is more of 720x576) ?
    thankssss!!!
    Sep 2012
    Australia
    http://avisynth.nl/index.php/Operators
    Colormatrix = src.width>720 || src.height>576 ? 709:601
    src = src.width!=720 || src.height!=576 ? src.IResize(720, 576): src
    You'd have to deal with aspect ratios in the batch though.
  10. Originally Posted by ndjamena View Post
    FFVideoSource("c:\GOPR1239HD25fps.MP4")
    src=last
    Colormatrix = src.width>720 src.height>576 ? 709:601
    Clip
    SeparateFields()
    Interleave(E, O)
    Weave()
    AssumeTFF()
    SeparateFields()
    Interleave(Ev,Od)
    Weave()
    ChangeFPS(25)
    AssumeFPS(25)
    Sep 2012
    Australia
    In case anyone is wondering, there's an OR operator on the on the Colormatrix line that the forum seems to be hiding. It shows if I try to 'quote' it though.
  12. mmmmmm Click image for larger version
  13. please cats I need to do another script that do this:
    load and convert all in 1920x1080HD except the source that are jet 1920x1080@25i AND if the source is SD BT601 ----> the script have to convert the source from 601 to 709
    As source, in this case, I use a 1440x1080@25i bt.709 .mxf file
    https://www.dropbox.com/s/df51oo8m5otdxnl/C0015.MXF?dl=0
    It have to be convert in fullHD
    I try with this script but I think there is a problem in the line of the colormatrix: using a SD (720x576) seems it don't do the 601-->709 colormatrix conversion. It should have to do the colormatrix conversion bt.601-->bt.709 when a SD file have resolution < (or equal) of 720x608
    FFVideoSource("g:\xdcamF335\C0015.mxf")
    src=last
    Colormatrix = src.width<721 src.height<609 ? 601:709
    src = src.width<1920 || src.height<1080 ? src.IResize(1920, 1080): src
    Clip
    SeparateFields()
    Interleave(E, O)
    Weave()
    AssumeTFF()
    SeparateFields()
    Interleave(Ev,Od)
    Weave()
    ChangeFPS(25)
    AssumeFPS(25)
    All is ok with C0015.mxf, but when I use a SD source the colormatrix conversion seems don't work
    Is there a way to resolve?
    thanks
    Sep 2012
    Australia
    If you object to being called 'anyone' I'll happily call you no one.
  15. Originally Posted by ndjamena View Post
    but I'm a cat !!
    so the line how become?
    Sep 2012
    Australia
    I don't know why it's doing that and am not interested in finding out. Go back to post #9 and press 'quote' to see it properly.
  17. Click image for larger version
    in this case source is a 720x608 mxf SD file that need to ben cropped.
    c:Click image for larger version
    But, for kindness, can I add a line that recognize if source is a 720x608 and a .mxf file (or simply a 720x608) -------[then]------> crop(0,32,0,0) ?
  18. Originally Posted by marcorocchini View Post
    avisynth cannot distinguish between containers (mxf vs. mp4 vs. mkv etc....), because it frameserves uncompressed video
    Only clip properties
    http://avisynth.nl/index.php/Clip_properties
    Sep 2012
    Australia
    You'd have to do it from the batch.
    By the way:
    "FFmpegSource2 indexing app\n"
    Usage: ffmsindex [options] inputfile [outputfile]\n"
    "If no output filename is specified, inputfile.ffindex will be used.\n"
    "\n"
    "Options:\n"
    "-f Force overwriting of existing index file, if any (default: no)\n"
    "-v Set FFmpeg verbosity level. Can be repeated for more verbosity. (default: no messages printed)\n"
    "-p Disable progress reporting. (default: progress reporting on)\n"
    "-c Write timecodes for all video tracks to outputfile_track00.tc.txt (default: no)\n"
    "-k Write keyframes for all video tracks to outputfile_track00.kf.txt (default: no)\n"
    "-t N Set the audio indexing mask to N (-1 means index all tracks, 0 means index none, default: 0)\n"
    "-d N Set the audio decoding mask to N (mask syntax same as -t, default: 0)\n"
    "-a NAME Set the audio output base filename to NAME (default: input filename)\n"
    "-s N Set audio decoding error handling. See the documentation for details. (default: 0)\n"
    -m NAME Force the use of demuxer NAME (default, lavf, matroska, haalimpeg, haaliogg)"
    They're the instructions for FFMSIndex, apparently the only way to see them is to run FFMSIndex.exe with no arguments, I had to look at the source code to figure that out.
    So you can put the index file where ever you like by adding it as the second argument then reference it with the "cachefile=" option in FFVideoSource.
  20. off topic, but thank you for bringing up that IResize, something that handles flickering ...
  21. Click image for larger version
    sorry my cat have a question:
    can avisynth don't out audio? so virtualdub have No Audio?
  22. Originally Posted by _Al_ View Post
    is poison that suggest it ^^^^^
  23. Originally Posted by ndjamena View Post
    By the way:
    thank for this particular, hoewver for I think is enought the only 720x608 .. only the IMX broadcast .mxf files have this bastard resolution ^^ so when the script recognize the only 720x608 is ok
  24. Originally Posted by marcorocchini View Post
    Instead of
    FFVideoSource()
    #this is for VIDEO only, hence FFVIDEOSource
    Use
    FFMpegSource2("video.ext", atrack=-1)
    or
    aud=FFAudioSource("video.ext")
    vid=FFVideoSource("video.ext")
    AudioDub(vid,aud)
  25. ndjamena can I ask you a question?
    this is "your" mega powerful batch that I usually use. It filter only .mxf files, but can I modify it so that:
    1) it accept, for example .mxf and .avi files?
    or
    2) it accept all extensions?
    @rem unless otherwise specified for debugging reasons turn echo off
    @if "%EMode%"=="" Set EMode=ON
    @ECHO %EMode%
    @ECHO off
    xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\system32
    xcopy /y v:\automazioneclip\system\morgan\m3jpSD.INI c:\windows
    xcopy /y v:\automazioneclip\system\morgan\m3jpHD.ini c:\windows
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegHD.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG32.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\m3jpegSD.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\morgan\MMIJG30.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\lcodccmp2.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\x264VFW.dll c:\windows\SysWOW64
    if exist c:\windows\SysWOW64 xcopy /y v:\automazioneclip\system\pvmjpg40.dll c:\windows\SysWOW64
    md c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\wavdest.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SamplesDropper.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SP_audio.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\dv_grabber.ocx c:\windows\spvideo
    xcopy /y v:\automazioneclip\system\SP_video.ocx c:\windows\spvideo
    regsvr32 /s c:\windows\spvideo\wavdest.ocx
    regsvr32 /s c:\windows\spvideo\SamplesDropper.ocx
    regsvr32 /s c:\windows\spvideo\SP_audio.ocx
    regsvr32 /s c:\windows\spvideo\dv_grabber.ocx
    regsvr32 /s c:\windows\spvideo\SP_video.ocx
    regedit /s v:\automazioneclip\system\VDreg.reg
    regedit /s v:\automazioneclip\system\PICreg.reg
    regedit /s v:\automazioneclip\system\drivers.reg
    del v:\automazioneclip\output\temp.avi
    del v:\automazioneclip\output\temp.wav
    cls
    SetLocal DisableDelayedExpansion
    Set "EXTLIST=*.mxf"
    Set "DoPop=0"
    Set "ARGLVL=0"
    Set "FileName-DQ="
    Set VDM_LOC="v:\automazioneclip\VirtualDubMOD\virtualdubmod.exe"
    if not exist v:\automazioneclip\output\progetto3 mkdir v:\automazioneclip\output\progetto3
    set "DestFolder=v:\automazioneclip\output\progetto3"
    Set "WorkFolder=%DestFolder%"
    if not exist %DestFolder% mkdir %DestFolder%
    rem process the arguments one by one
    :ARGS
    	rem if there are no further arguments then exit the batch.
    	if [%1]==[] (
    		if "%ARGLVL%"=="0" (
    			CALL :GetTargetName
    			EndLocal
    			pause
    		goto :eof
    	rem wildcard processing
    	Set "FileName=%~1"
    	if "%FileName%"=="" (
    		SHIFT
    		goto :ARGS
    	rem if the argument doesn't exist in the file system in any form skip it.
    	if NOT EXIST %1 (
    		SHIFT
    		goto :ARGS
    	if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" (
    		for %%w in (%1) DO (
    			Set /a ARGLVL+=1
    			CALL :ARGS "%%~fw"
    			Set /a ARGLVL-=1
    		SHIFT
    		goto :ARGS
    	Set "FileName="
    	rem Set search/recursion variables
    	Set "Pattern=%EXTLIST%"
    	Set "STARTLVL=0"
    	Set "FOUNDLVL=1024"
    	rem if the argument is the current directory then process everything in it.
    	if "%~f1"=="%CD%" (
    		rem echo Processing Directory "%CD%"
    		CALL :START %1
    		SHIFT
    		goto :ARGS
    	rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file.  Then return to starting directory.
    	Type NUL
    	pushd "%~f1" 2> nul
    	if NOT "%errorlevel%"=="0" (
    		if NOT "%CD%\"=="%~dp1" (
    			pushd "%~dp1"
    			Set "DoPop=1"
    		Set Pattern="%~nx1"
    	) else (
    		rem echo Processing Directory "%~f1"
    		Set "DoPop=1"
    	CALL :START %1
    	if "%DoPop%"=="1" (
    		popd
    		Set "DoPop=0"
    	SHIFT
    goto :ARGS
    :START <CURRENT_ARG>
    	rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes
    	Set "Count=0"
    	rem Process all files in the current directory fitting the arguments search pattern.
    	for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do (
    		if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy"
    	rem if it didn't find anything search all directories instead
    goto :eof
    	if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% (
    		for /d %%b in (*) do (
    			pushd "%%~fb"
    			rem echo Processing Directory "%%~fb"
    			Set /a STARTLVL+=1
    			CALL :START "%%~fb"
    			Set /a STARTLVL-=1
    			popd
    goto :eof
    :Process_File <MXF_FILENAME>
    	Set /a Count+=1
    	Set "FOUNDLVL=%STARTLVL%"
    	echo Processing "%CD%\%~nx1"
    	if /I NOT "%~x1"==".mxf" (
    		echo "%~nx1"
    		echo  Is not an mxf file.
    		pause
    		goto :eof
    	if EXIST "%DestFolder%\%~n1.avi" (
    		echo  File giÓ esistente nella directory di destinazione %DestFolder%
    		goto :eof
    	if EXIST "%WorkFolder%\%~n1.avi" (
    		echo  Working File Already Exists...
    		goto :eof
    		pause
    	rem Find TimeCode Info
    	Set AUCount=0;
    	for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\virtualdubmod\FFProbe -hide_banner -loglevel fatal -pretty -show_streams -show_entries stream^=codec_type^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version "%~1" 2^>^&1') DO (
    		 if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h"
    		 if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h"
    		 if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h"
    		 if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h"
    		 if "%%~g"=="width" set "V_Width=%%~h"
    		 if "%%~g"=="height" set "V_Height=%%~h"
    		 if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h"
    		 if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1
    	if "%V_Width%"=="" (
    		echo  ERROR: Video Width NOT FOUND!
    		pause
    		goto :eof
    	if "%V_Height%"=="" (
    		echo  ERROR: Video Height NOT FOUND!
    		pause
    		goto :eof
    	if "%V_PAR%"=="" (
    		echo  ERROR: Video PAR NOT FOUND!
    		pause
    		goto :eof
    	rem Set "V_Q=UD"
    	rem if %V_Width% LEQ 1920 if %V_Height% LEQ 1120 \\
    	Set "V_Q=HD"
    	rem if %V_Width% LEQ 1280 if %V_Height% LEQ 752 Set "V_Q=MD"
    	if %V_Width% LEQ 1024 if %V_Height% LEQ 608 Set "V_Q=SD"
    	echo  Using %V_Q% Mode
    	echo  PAR = %V_PAR%
    	if "%TimeCode%"=="" echo Warning! no TimeCode Found!
    	if NOT "%TimeCode%"=="" echo Timecode= %TIMECODE%
    if "%V_Q%"=="SD" (CALL :MAKEVCF_SD "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    if "%V_Q%"=="HD" (CALL :MAKEVCF_HD "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1")
    rem CALL :MAKEVCF "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1"
    	echo  FATTO
    	echo.
    	echo ---------------------------------------------
    	echo.
    	EndLocal
    goto :eof
    :MAKEVCF_HD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME>
            v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -filter_complex "[0:1] [0:2] amerge,volume=2.0" -c:a pcm_s16le %WorkFolder%\%~n1.wav
            v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -filter_complex "[0:3] [0:4] amerge,volume=2.0" -c:a pcm_s16le %WorkFolder%\%~n1ch3ch4.wav
    	rem ***Make The .vcf Script File***
    	echo VirtualDub.RemoveInputStreams^(^)^;>%1
    	echo VirtualDub.video.DeleteComments^(1^)^;>>%1
    	if NOT "%TimeCode%"=="" echo VirtualDub.video.AddComment^(0x0000000C,"","%TIMECODE%"^)^;>>%1
    	echo VirtualDub.video.AdjustChapters^(1^)^;>>%1
    	echo VirtualDub.video.SetDepth^(16,16^)^;>>%1
    	echo VirtualDub.video.SetMode^(1^)^;>>%1
    	echo VirtualDub.video.SetFrameRate^(0,1^)^;>>%1
    	echo VirtualDub.video.SetIVTC^(0,0,-1,0^)^;>>%1
    	echo VirtualDub.video.SetCompression^(0x31626d64,0,10000 ,0^)^;>>%1
    	echo VirtualDub.video.filters.Clear^(^)^;>>%1
    	rem ***Make The .avs AVISynth Script***
    	echo FFVideoSource^(%4^)>%2
            echo AssumeFPS^(25^)>>%2
    	rem ***Call VirtualDub[Mod]
    	if NOT EXIST %VDM_LOC% (
    		echo  Um, where the hell is VirtualDubMod?
    		pause
    	%VDM_LOC% /s%1 /p%2,%3 /r /x
    	if NOT "%ERRORLEVEL%"=="0" (
    		echo  WARNING!!!  VirtualDubMod Error Detected!!!
    		pause
    	for %%v in (%3) do (
    		if %%~zv LSS 128 (
    			echo  ERROR!!!  Extra Small File Size Detected!!!
    			pause
            v:\automazioneclip\virtualdub\cfourcc.exe -i %3 -u MJPG -d MJPG
    	rem Clean-up
    	DEL %1
    	DEL %2
    	DEL %CD%\*.FFINDEX
    goto :eof
    :MAKEVCF_SD <VCF_FILENAME> <AVS_FILENAME> <AVI_FILENAME> <MXF_FILENAME>
            v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -map_channel 0.1.0 -map_channel 0.1.1 -af "volume=volume=9dB:precision=fixed" %WorkFolder%\%~n1.wav
            v:\automazioneclip\core\ffmpeg.exe -loglevel fatal -y -i "%CD%\%~n1.mxf" -map_channel 0.1.2 -map_channel 0.1.3 -af "volume=volume=9dB:precision=fixed" %WorkFolder%\%~n1ch3ch4.wav
    	echo VirtualDub.video.SetCompression^(0x6a6d7674,0,10000 ,0^)^;>>%1
    	echo VirtualDub.video.SetCompData^(28,"TUpQRxgAAAAAAAAAAgAAAAgAAAACAAAAAQAAAA=="^)^;>>%1
    	echo Crop^(0,32,0,0^)>>%2
    		pause
    		pause
    		if %%~zv LSS 128 (
    			pause
    	rem Clean-up
    	DEL %1
    	DEL %2
    	DEL %CD%\*.FFINDEX
    goto :eof
    :GetTargetName
    	Set "FileName="
    	Set /p FileName=InputFileName.mxf o InputFolder - INVIO per convertire tutto (EXIT esce):
    	rem Add or remove double-quotes if necessary
    	if NOT DEFINED FileName (
    		Set "FileName-DQ="
    		goto :DQSkip
    	Set "FileName-DQ=%FileName:"=%"
    	if NOT DEFINED FileName-DQ (
    		Set "FileName="
    		Set "FileName-DQ="
    		goto :DQSkip
    	if EXIST "%FileName-DQ%" (
    		if "%FileName-DQ%"=="%FileName-DQ: =%" (
    			Set "FileName=%FileName-DQ%"
    		) else (
    			Set FileName="%FileName-DQ%"
    :DQSkip
    	if /I "%FileName-DQ%"=="" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="CD" Set FileName="%CD%"
    	if /I "%FileName-DQ%"=="EXIT" goto :eof
    	if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName
    	if DEFINED FileName (
    		Set /a ARGLVL+=1
    		CALL :ARGS %FileName%
    		Set /a ARGLVL-=1
    goto :GetTargetName
  26. Member
    Sep 2012
    Australia
    EXTLIST is called EXTLIST for a reason.
    Set "EXTLIST=*.mxf *.avi"
  27. Member
    Sep 2012
    Australia
    You'll also have to modify the file extension code in Process_File:
    if /I NOT "%~x1"==".mxf" if /I NOT "%~x1"==".avi"
    If you intend on adding many file extensions, replacing that section with a for loop may be in order.
  28. thanks ndjamena, only another question and I let yiu quite:
    in the batch, I cannot transpose some line (in red)
    the batch have to generate this
    FFVideoSource("w:\cesenacalcio\c0075.mxf")
    src=last
    src=src.width==720&&src.height==608?src.crop(0,32,0,0):src
    src=src.width>720||src.height>608?src.ColorMatrix(mode="Rec.709->Rec.601"):src
    src=src.width!=720||src.height!=576?src.IResize(720,576):src
    Clip
    SeparateFields()
    Interleave(E, O)
    Weave()
    AssumeTFF()
    SeparateFields()
    Interleave(Ev,Od)
    Weave()
    src.framerate<26?src:src.AssumeTFF().SeparateFields().SelectEvery(4,0,3).Weave()
    ChangeFPS(25)
    AssumeFPS(25)
    This lines are accepted: but I caannot insert the red lines above
         echo FFVideoSource^(%4^)>>%2
         echo function IResize^(clip Clip, int NewWidth, int NewHeight^) {>>%2
         echo Clip>>%2
         echo SeparateFields^(^)>>%2
         echo Shift=^(GetParity() ? -0.25 : 0.25) * ^(Height()/Float(NewHeight/2)^-1.0^)>>%2
         echo E  = SelectEven^(^).Spline36resize^(NewWidth, NewHeight/2, 0,    Shift^)>>%2
         echo O  = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0,   -Shift^)>>%2
         echo Ec = SelectEven^( ^).Spline36resize^(NewWidth, NewHeight/2, 0,  2*Shift^)>>%2
         echo Oc = SelectOdd^( ^).Spline36resize^(NewWidth, NewHeight/2, 0, -2*shift^)>>%2
         echo Interleave^(E, O^)>>%2
         echo IsYV12^(^) ? MergeChroma^(Interleave(Ec, Oc)^) : Last >>%2
         echo Weave^(^)>>%2
         echo } >>%2
         echo AssumeTFF^(^)>>%2
         echo Ev=SelectEven^(^).sharpen(0.20^)>>%2
         echo Od=SelectOdd^(^).sharpen^(0.20^)>>%2
         echo Interleave^(Ev,Od^)>>%2
         echo Weave^(^)>>%2
         echo ChangeFPS^(25^)>>%2
         echo ConvertToYUY2^(interlaced=true^)>>%2
    Can you help me ?
  29. I can only do:
    echo src=last>>%2
    this is ok, but the others red dont' wont
  30. Member
    Sep 2012
    Australia
