  1. I download files no problem using get_iplayer
    The files are saved as mp4
    However I'm told that due to DRM protection I cannot save them for posterity ...they will self destruct after 30 days.
    Several links followed on lne but most come back to Amerisoft/Danusoft/Convertiplayer ....... but that is not free.
    Are there any free utilities to remove DRM and presumably re-encode as 'clean' mp4 format
  2. Member DB83's Avatar
    Jul 2007
    Well I read that as well
    What I have done is simply move the downloaded file to a different location (from the default download folder created by get_iplayer) and my downloads survived.
    Have not done this for some time so it may no longer work.
    As for removing the DRM, that methinks is a taboo question.
  3. Banned
    Freedonia
    The only way I know of in this type of case to deal with DRM is not to actually remove it, but to instead use a streaming media recorder that records the video in real time while it plays and saves it. The final saved file will not have DRM. You will have to buy a program to do this. I don't think there are any free programs that can do it very well. This is actually how the "DRM remover" programs really work. They play the file in real time in a way so that you aren't aware it's actually playing (no obvious display of the playing file) and they record it in real time. "Real time" means 1 hour of video takes 1 hour to record. I've never heard of any programs that can actually remove BBC DRM, but to be honest with you as I live in the USA I can't say I have done exhaustive research on the subject.
  4. Originally Posted by Tafflad View Post
    If you watch in iPlayer using a web browser, you can download the .flv version using something like Internet Download Manager.
    See attached image showing the download of episode 3 of the dreadful "Boomers". Yuck.
Name:	2014.08.30_15h53m03s_001_37- BBC iPlayer - Boomers - Episode 3-flv.jpg
  5. Originally Posted by mike20021969 View Post
    The BBC may have just updated it's DRM so this program wouldn't work.
  6. Member bat999's Avatar
    Feb 2008
    However I'm told that due to DRM protection...
    If the files are downloaded with get_iplayer v2.94 they don't have any DRM protection.
