  1. Hi, I have a lot of subtitles(srt's) that I would like to edit using Subtitle Edit or Gaupol mostly from anime.
    What I'm trying to do is to delete a specific lines lets say with a word "Visit...". I dont wanna do it one by one as it is time consuming.
    Is there any way to do this using batch file or alternatives that can do the same?
  2. Since srt subtitles are just text, you could probably create a macro in a word processor that would search for the word and delete the line.
    Jul 2011
    Denmark
    In Subtitle Edit you could use Tools -> Batch convert, enable "Multiple Replace" with a regular expression like "Visit.*"
  4. Originally Posted by Nikse View Post
    Thanks for your response. I tried what you suggested but nothing happened. I entered the exact words that I would like to be removed along with the whole line in "Find What" and it only replaced the words and not delete the line.
    & it might not be possible but I want to double check in case I'm missing something. Is it possible to choose the output folder in the same directory as the original file and maybe just add (1) at the end?
    Thank you.
    ***UPDATE***
    It worked! My mistake. I put it under "normal" instead of "regular expression". This will save me hours of time.
    Pls answer my answer above about the output folder & is there anything I should be caution about the batch convert process or its pretty much straight forward? I just don't want to convert them all at once then after muxing all the videos then I find mistakes then I had to fix them all one by one.
    Jul 2011
    Denmark
    Sorry no.
    Also, "Visit.*\r\n.*" will be needed if a subtitle has two lines - you can right-click in the "Find what" textbox for regex help.
  6. Originally Posted by Nikse View Post
    Sorry no.
    Thank you very much. This will come in handy.
