  1. Hello,
    I got a question. When I encode now a DVD with handbrake to .mp4. And I realize later that I need to add subs, what would be the best way?
    Can I use mkvtoolnix and just mux the srt into the file? Won't that change the codec? It saves my file then as .mkv which I don't what, can I change the save to .mp4 without any loss?
    Also how can I convert .mp3 audio to .ac3 audio usually 2ch the easiest way without any shareware?
    cheers
    1. You can use mp4box or a gui for it like mymp4boxgui.
    2. Taudioconverter.
  3. Originally Posted by Baldrick View Post
    2. Taudioconverter.
    Thank you!
    So was I right, the codec does really change when I mux the srt into my .mp4 in mkvtoolnix?
    Even tho I save it as .mp4?
    cheers
    canada
    It just changes the package,not the codec.,mkv is a better format to mux to anyways.
  5. @johns0: Why if you have mp4 compatible content use mkv?
    users currently on my ignore list: deadrats, Stears555
  6. I'm a Super Moderator johns0's Avatar
    canada
    I just said mkv is a better format to use,i didn't say to use it if it's gonna be used for a ps3 or apple device.Lot of people use mp4 cause that's what they are used to.
