  1. When using DVDFab Copy for Blu-ray, I get the "Specify region code" message, which asks me to select from regions 1, 2 or 3. I want to rip the Blu-ray and remove the region code. In order to do this, do I need to select the same region code as on the back of the Blu-ray packaging (as stated in this link http://www.dvdfab.cn/manual/passkey/DVD) or will the region code be removed no matter which region I select?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Using the discs actual region code stated on the package is highly recommended. I doubt it is a game-changer if you put the wrong one by mistake however, it will still get done. All copies are region free.
  3. Okay, thanks. If the disc is region free, I guess it doesn't matter which region I select?
  4. Banned
    Freedonia
    With AnyDVD it doesn't, but I don't have DVDFab to test with. Would it kill you to just try it? Geez, if you had tried it already instead of spending hours in this thread, you could quite possibly already be done instead of getting all hung up on having people give you 100% guarantees about everything before you even try. What exactly do you think is going to happen if it doesn't work? It's not like DVDFab is to destroy your PC permanently if you answer this question wrong.
  5. According to my knowledge, the software may remove the region code by changing the original region code into "all region code" , you can play it on any players. If you select a wrong region code, the output disc may have problems in content.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    WRONG.
    The software isn't asking you what region you WANT the copy to be, it is asking what region the original disc is straight from the package.
  7. Originally Posted by hech54 View Post
    WRONG.
    Yes, the software is asking you to select the original region for the disc.
