Results 1 to 9 of 9
  1. Hi! I have some bd 3d iso's and i want to remove all dont needed things like languages, extras, etc. Usually with not 3d iso, i use makemkv. i cant do this with 3d, because in this way, the resulting mkv will be 2D. If, instead, the resulting file is still iso, then my mediaplayer plays it in 3d. Are there any software's for mac? thanks
    Feb 2014
    QUÉBEC
    BDinfo to find out which ''.mpls'' file to use and TSmuxer for remuxing
    You can also rip to mkv 3D using MakeMKV. The mkv will be 2d/3D.
  3. Originally Posted by imhh1 View Post
    using the first 2 softwares, its will still an iso file? as ive said above, with makemkv, even if i select the 3d extension, resulting file is still 2d
    Feb 2014
    QUÉBEC
    yeah tsmuxer produce 3D iso file
  5. Banned
    Freedonia
    This is news to me. Exactly how does tsmuxer produce an ISO then?
    Feb 2014
    QUÉBEC
    just select Bluray iso for the output (version 2 and +)
  7. it seems tsmuxer dont opens iso. im extracting it... 1hour remaining even if im extracting from usb 3.0 hd to a ssd...
    Feb 2014
    QUÉBEC
    You cannot drag the iso directly to Tsmuxer
    -Mount the iso first with DVDfab virtual drive or any image emulator , then import the good MPLS into tsmuxer: ''\BDMV\PLAYLIST'' using BDinfo , after that you can remux to an iso. it should take only 15 minutes, no reencoding
    and if you dont understand , you can use your MKV made with Makemkv (dont forget to select the MVC 3D) and then create the bluray iso with tsmuxer . But it is one more step.
    for more info about Tsmuxer 3D remux visit http://forum.doom9.org/showthread.php?t=168539
  9. Originally Posted by imhh1 View Post
    ok i did it first with makemkv, selecting the mvc 3d extension. then iso with tsmuxer. it works! again i dont understand why this 3d extension dont work if the file is mkv. the only 3d mkv's that works are the sbs. also, when i add the "cleaned" mkv to mkvmerge, i have only the video and the audio. on tsmuxer i have also the 3d extension....
