Results 1 to 11 of 11
  1. Hello,
    I prefer standalone tools vis-a-vis installable ones.
    If possible, please have a separate section for Standalone tools, it will be so much convenient.
    Thank you.
    I will see what I can do. I must first update all tools that have only a portable version....meaning manually go through all 1048 tools.
    I can easily show all tools that have both a portable and installation:
    http://www.videohelp.com/tools?portable=portable
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You can add Aviutl to that list, no need to install. I'm sure there are many more also.
    Yep. And most tools that are stored in a zip/7z/rar file also....but not all.
  5. Originally Posted by Baldrick View Post
    1048 tools!
    Thanks, Baldrick.
    Your link displays 78 results.
    If I use this link
    http://www.videohelp.com/tools?toolsearch=portable&submit=Search&s=&orderby=Name&hits=50
    I get 33 results.
    I think, it is OK. I think doing it manually is not required.
    Thanks for your suggestion.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Yes. I'm going to update all tools manually. It won't take that long.
  7. DECEASED
    Jun 2009
    Heaven
    Semi-OT
    "Lame ACM" redirects to "LAME MP3", however this latter has no link to the respective Rarewares page
    (apparently the recent versions of the LAME "bundle" do not include the ACM codec ).
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    I added a download link to lame acm also (under more download options).
  9. DECEASED
    Jun 2009
    Heaven
    Many =^.^=
  10. Originally Posted by El Heggunte View Post
    Many =^.^=
    Thanks, Baldrick
