  1. I ve never used ripbot before but i get this error when i try to import an Avi file
    http://i.imgur.com/UmalG17.jpg
  2. What happens when you open it in VDub? Same thing? What kind of video is it? Can you use a different source filter? DirectShowSource shouldn't be used unless nothing else works. What's the complete script? What happens when you don't include the audio in the script?
  3. Originally Posted by manono View Post
    i press add choose the video wait and this happens.
    I don't know what Vdub does someone recommended ripbot in order to reduce the size of the file so i can upload it in youtube.
  4. I use RipBot264 a lot myself, to put videos in a format YouTube accepts (MP4 with x264 video and AAC audio). I don't use Ripbot to shrink the size of something that's already in a format YouTube supports, which is what you seem to say you're using it for.
    The use of VDub is only to test the script. You didn't give the script or answer any of the other questions, so maybe someone else can help. Good luck.
  5. Originally Posted by manono View Post
    I searched for my error i couldnt really find a solution only that someone reinstalled the ffdshow and it worked but not for me
    also i have windows 7 64 bit maybe thats the case i dont know im newbie at this stuff.
    edit: i used the original file without being rendered and it worket so i guess i need appropriate rendering.
