    Aug 2014
    Switzerland
    Hi,
    Pls I would like to know how to put 2 or 3 different ''markin/out'' in a video
    for example:
    I have a 20min video and I'd like to cut it at 3 different places
    pls see the attached pic (I did it with photoshop)
    thanks
    regards
    Dec 2005
    Canada
    If you want to remove sections, you must mark the beginning /end of the first section and press the 'Del' key then repeat as required.
    Aug 2014
    Switzerland
    so, no multiple marks... ok
    thanks
    Dec 2005
    Canada
    For multiple cuts, I think you would have to use VirtualDub and an AviSynth script (in this example, "Trim" shows the range of frames you want to keep - not discard.
    The drawback is that the output from VirtualDub has to be recoded.
    avisource("clip.avi")
    Trim(0,50)+Trim(80,90)+Trim(500,600)+Trim(900,1000 )
    Aug 2014
    Switzerland
    I see
    thanks for the tip
