  1. I'm using PotPlayer with default and recommended settings such as Video Renderer - Select Automatically (Recommended) on my HTPC with these specs,
    CPU: Intel Atom 230 1.6GHz (Single Core)
    GPU: Nvidia ION intergared graphics
    RAM: 2GB DDR2
    How do I make PotPlayer to use GPU for videos instead of CPU as it's only single core? Also is there a way to display stats such as CPU and GPU usage while playing a video?
  2. Also is there a way to display stats such as CPU and GPU usage while playing a video?
    Press 'Tab' key while playing. You'll get some useful info.
    I'm not sure if it will work with your system.
    http://goo.gl/2OmDZE
