Results 1 to 11 of 11
  1. http://ffmpeg.mplayerhq.hu/
    Converting videos and audios has never been so easy.
    Killing videos and audios too.
    (do not) try this one, and your source is gone ...
    $ ffmpeg -loop -i input.mp4 output.avi
    Yes, it's a syntax error I made myself by forgetting the argument (-loop 1). Perhaps I'm the only one who makes mistakes now and then, especially when the clock passed midnight, but still. It seems to do this with every command before the input. Not only -loop (e.g. also -threads).
    Why does FFmpeg not explicitly forces to use -o for the output path, like most other command line tools do, instead of doing a wild guess? Would make error checking for the developers much easier. Simply no -i no input, no -o no output = error.
    Yes I know I could report it but the FFmpeg procedure to report bugs or post suggestions is not the easiest around.
    Anyway, you are warned
    Chris
  2. Originally Posted by Chris K View Post
    And there is some politics and personalities involved about what gets accepted for review or not. My understanding is that's one of the big reasons for the split between libav / avconv vs. ffmpeg
  3. Yes I know I could report it but the FFmpeg procedure to report bugs or post suggestions is not the easiest around.
    Where is the problem in reporting a bug or feature request to their bug tracker (https://trac.ffmpeg.org/) ?
    users currently on my ignore list: deadrats, Stears555
  4. Originally Posted by Selur View Post
    Well, at first I'll have to register. At second I'll have to post the full FFmpeg log and thereafter as poisondeathray mentioned my report might not be accepted.
    Guess it's me. I'm just too lazy.
  5. I'm just too lazy.
    Seems like it.
  6. DECEASED
    Jun 2009
    Heaven
    That's it, https://trac.ffmpeg.org/ticket/3803
    Bottom-line is, when things are already broken, why should we ever care about fixing them?
  7. Originally Posted by Selur View Post
    I'm just too lazy.
    Seems like it.
    ... or to old.
  8. Sine you were able to register and post quite a few posts the last few days I would go with 'too lazy' and not 'too old'.
  9. Originally Posted by Selur View Post
    I did not register. I just logged in.
    I only wanted to warn and wondered why FFmpeg "thinks" that everything that is not a input, is a output.
  10. Code:
    Above example from the first post was slightly too limited to get the error (as is the example from the FFmpeg web site that suggest you get a useful output with that). FFmpeg here will still warn you that the input file already exists and if it should overwrite it.
    $ ffmpeg -loop -i input.mp4 -y output.avi
    However with the -y command added it will still kill the input file. Many use this command when they do some kind of batch processing with FFmpeg.
    Thought it's fair to post this correction.
    Chris
  11. DECEASED
    Jun 2009
    Heaven
    For the notes, twolame is much worse than ffmpeg, since its current maintainer (apparently a Linux troll) thinks it's OK that the source-code can't be compiled on Windows anymore:
    https://github.com/njh/twolame/issues/12
