    Jul 2014
    Purcellville, VA
    I am not too happy with the fluid head on my Magnus VT-3000. What would you guys recommend for a replacement? I am guessing that I will probably have to also buy an adaptor since it is a 65 mm half ball. The problem with the stock head is that I notice that the resistance is very strong no matter what the lock knob is set to. So when I start the pan I get a big jerk and then it is smooth. I cannot start out very smooth at all.
    Thanks,
    Mark
  2. 75mm and 100mm are common standards. Google turned up a couple of 65mm models from companies I have never heard of.
    You may want to start from scratch on this one. Manfrotto offers several good models at decent prices.
    I've never heard of an adapter, but I can't imagine using one would lead to anything but stability and smoothness issues.
  3. Maybe this one, but itīs a 60 mm. half ball head, you may or may not need an adapter, I dont know.
    http://www.bhphotovideo.com/c/product/944775-REG/manfrotto_mvh500a_pro_fluid_head.html
