    Sep 2012
    lancaster PA USA
    I am looking for an extension for IE, 64 bit win 7, that has a button right on the page you are viewing for, (Not for use with a URL), so I can download on the fly and have 1080p MP4 capability.,
    thanks!!
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I've been to Lancaster a few times, are you one of those guys on a horse and buggy I've seen on the side of the road?
    Anyway, you can try http://www.clipconverter.cc/ It's not as easy as a button, but it works pretty well.
  3. There's a download helper extension for IE. I use the Firefox Video Download Helper extension myself, but it appears it's unrelated to the IE extension, so I don't know how well the IE extension might work or what it can do. http://ie-downloadhelper.com/
    Sep 2012
    lancaster PA USA
    Thanks guys, but i found: Wondershare AllMyTube 4.2.0
    It does use URL's, but also has the button. It seems to be limited to 780p HD, but I am using it with IE as a backup to my FF.
    I had a problem yesterday wherein a video would not download with my program on FF and with this new program and IE i was able to get it to download. It worked quickly and had real good video/audio quality.
  5. video2mp3 is a great converter which can download seperate video format
