  1. So I had this BD/DVD-burner for about a year and once burned a 25GB BD-RE with it. But now having reflashed to v 1.35, the drive neither burns nor reads BD disks. It reads/writes CDs/DVDs alright.
    I tried to revert the firmware to the old version but the firmware doesn't allow to downgrade.
    Do you know a utility that would allow me force flash the drive? Obviously other helpful comments are welcome.
  2. The most obvious step would be to contact Pioneer. You can't be the first person to encounter this.
  3. Member turk690's Avatar
    Jul 2003
    ON, Canada
    Before you arrive at this conclusion, be sure to obtain a range of known good BDs, both pressed and recordable and see. If you just tested it with that BD-RE that you burned "once", and the disc wasn't closed, then it won't be recognized because updating the f/w makes the burner practically a different one post- f/w update.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
    Mar 2009
    When I looked up the current version flash, it stated that 1.21 is the most current version. Anything else above that is not recommended and there is none out yet. You may have to wait for company to come out with a flash that is made for it.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    maonstad - you must have only looked at the poorly maintained u.s. pioneer site. you need to check the japan site for the complete list.
    aquanax - did you shut down windows and power off the computer before re-starting and trying it?
    Mar 2009
    You are right. But I did find 1.30 works... 1.35 had problems.... from other posts.
  7. Banned
    Freedonia
    In that case the OP will have to wait for 1.36 to be released.
    I really do not understand why some people insist on regularly updating their firmware and risking problems. I've got a Pioneer BD burner that's about 3 years old and I've never updated the firmware after installing it. I've also never had a problem with it. Usually the new firmware contains fixes for problems most users will never see and write strategies for new manufacture runs of discs, but if you use ImgBurn and high quality discs you don't need to update firmware to write to discs.
    If the OP is using BD-R LTH discs, it is possible that a new firmware update broke compatibility with those. BD-R LTH discs are tricky. My Pioneer will burn them and read previous burns but my other BD burner, an LG model, can neither burn nor read LTH burns.
  8. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    I think "reflashed" is the wrong term and leads to misunderstandings...
    RE media is always a gamble, even more with BDs these days.
    *** Now that you have read me, do some other things. ***
