    Jul 2014
    US Mid-West
    I just upgraded from a computer that ran Windows Vista to one that runs Windows 7. I've had a lovely system of being able to rip DVDs in Roxio while running DVD43. However, the latter doesn't work on Windows 7 64bit. I tried the trial of AnyDVD, and it worked just like DVD43 did. However, I don't have the budget for the program. Is there something else that would achieve the same result of being able to select the DVD in Roxio Capture? Thanks for any help!
  2. You could use dvdfab decrypter to rip your disc to hard drive.
    I am not familiar with roxio so not able to discern what the program is doing for you.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    You could try Passkey Lite it's free and will make the disc region free so your ripping program works http://www.videohelp.com/tools/DVDFab-Passkey#features
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
    Jul 2014
    US Mid-West
    I will try those two and see if it works. What DVD43 (and now AnyDVD) does with Roxio is that I can open the capture screen and instead of it only recognizing my hauppage capture card, it also sees the DVD drive. I select the disc drive and it displays the DVD and I can select by chapter or special feature what I would like to download. I select and begin the capture process. I rips an mpg file of each chapter I've selected. The mpg file is playable and edits perfectly in my Pinnacle Studio 11.
    Jul 2014
    US Mid-West
    Hi, everyone! I got a successful replacement to DVD43 for ripping through Roxio capture. DVDPaskey lite worked perfectly! I tried four different DVDs and each one has been great. Many thanks for all your help! I am so happy!
  6. Originally Posted by jagabo View Post
    I believe this is an plugin for BluFab (DVDFab). It's, apparently, the driver Passkey uses.
    True? Not sure. Just what I read somewhere.
    Sep 2011
    Anyone actually use woookao yet to see if it works with any of the other programs?
