  1. Been googling a lot for past 2 days looking for a software or a GUI for FFDSHOW video filter, is there a possible video converting software that will use FFDSHOW video filter so i can make video look like 1080p or 720p. first i upscaled it then I use warp-sharp tool from FFDSHOW filter, the main problem is that i want to wait or record while the video is playing, it takes too long, then i have to encode it! so is there a faster way?
  2. DECEASED
    Jun 2009
    Heaven
    There exists a VfW interface for ffdshow, so that you can use it in VirtualDub or AviUtl, for example.
  3. Another option is using avisynth with DirectShowSource() and the DirectShow ffdshow configuration .
    But usually there are equivalent filters in avisynth that you can use without ffdshow. e.g. you mentioned ffdshow's warpsharp
    http://avisynth.nl/index.php/WarpSharp_YV12
  4. Cool I'm going to try them, thanks!
  5. You can call ffdshow preset directly in Avisynth or with graphedit do everything directly (especially with older version fddshow where more encoders was available)
