    May 2006
    I downloaded a Video file ,and when I opened the Folder,I got a bunch of VOB files,.
    Can I turned this folder into an ISO?
  2. ImgBurn -> Write Files/Folder To Disc -> Select Folder -> Burn
  3. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    niteghost, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
  4. DVD Shrink will convert it to ISO. Just make sure compression is disabled, or set the target output size to something large in DVDShrink's preferences so it won't try to shrink the video (DVD9 or larger). That way, you don't need to remember to disable compression every time you open a folder/disc.
  5. Originally Posted by jagabo View Post
    The OP wants an ISO image.
    ImgBurn > Create image file from files/folders > Build
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yep ImgBurn
    And if you want to burn it to a DVD, save a step and just burn the VIDEO_TS folder to a disc with ImgBurn
