    Jun 2010
    Toulouse, France
    Hello Folks,
    This is my first post!
    I have many .ts files from TV, but when I use tsmuxerGUI to cut a head or tail off, then all the sub titles disappear! Normally I have 4 audio paths, and also 4 subtitles!
    Thank you!
    --soborobo
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Not sure what system is in play in France, if it is MPEG2 + Audio +subs etc then topping and tailing before extracting the subs etc by demuxing will remove important header information. Before any editing of the original TS file you need to demux the file into it's elementary tracks, this will give you the video. audio and all the subs.
    If the system is similar to Germany and Australia ie PAL MPEG2 + Audio +subs etc then use ProjectX to Demux and edit in ProjectX to maintain subtitle sync.
    Post a MediaInfo report of a file before any editing, will help in identifying the parameters of the file....
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
    Jun 2010
    Toulouse, France
    Hello,
    That sounds like overkill!
    Because if I edit the video removing stuff! Then the same has to be done to the subtitles! sounds complicated!
    Thankd anyhow!
    --soborobo
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    No not at all - if you edit within ProjectX and then demux with ProjectX all one operation, you will extract the subs in sync with the video and audio. If you edit a TS file before extracting the subs you won't be able to do so, as you discovered. It takes me all of 5 minutes to top n tail edit out commercials and demux. I then drag and drop the audio, video and SRT files into MKVMergeGui to produce a MKV file. This takes 2 minutes. No re-encoding or loss of quality. voila!
