Results 1 to 12 of 12
  1. Hi all,
    I've downloaded a MP4 movie and i found in it a japanese subtitles. How can i remove it to be able to put my language subtitles?
    Regards,
  2. DECEASED
    Jun 2009
    Heaven
    Just buy the Blu-Ray or DVD. OR find a better file to download.
  3. You don't have to remove subtitle from MP4
    Just rename SRT subtitle same name as movie
    and VLC automatically play video with SRT file
    anyway Yamb, My MP4Box GUI and MP4Muxer can mix mp4
    or you can mix to MKV with MKVToolnix
  4. Originally Posted by roma_turok View Post
    1- I did that, and i got the two subtitles on each other (Japanese and English).
    2- I did that too, but i usually gets two files after mixing, one is the movie file (without sound and the japanese subtitles still there) and the sound for the movie MP4 file!
  5. DECEASED
    Jun 2009
    Heaven
    I suspect that the MP4 file has "hard-coded" subtitles, and these cannot be removed...
    ... without screwing the picture quality as well. AFAIR, MP4s containing "soft subs" are somewhat uncommon ~~
    ~~ the format accepts only TTXT (officially) and IDX+SUB (unofficially).
  6. If you disable subtitles in VLC player, when you play original file
    and you have still displayed subtitles
    so yes, subtitles its part of video, it's cannot be removed
    Vlc disabled subtitles:
  7. Member KaddirB's Avatar
    Apr 2014
    Planet Earth
    Hello, if like El Heggunte says you have Hardcoded Subtitles than you can use sony vegas to remove subtitles heres a tutorial
    https://www.youtube.com/watch?v=6vSuRGIN7OA
    or you can try subtitle VirtualDub MSU Subtitle Remover heres a tutorial for that
    https://www.youtube.com/watch?v=hvdkkGJnyMo
    good luck.
  8. DECEASED
    Jun 2009
    Heaven
    ^ Maybe it was my usual "lack of good luck", but
    the only time I tried MSU subtitle remover on a video with CJK subtitles (years ago), it didN'T work,
    — I mean, it didn't remove anything : - /
  9. The MSU subtitle remover does not work because it specifically try to match the shape of English characters (I guess).
    A more universal remover requires the use of edge detection(for all shapes) and in-painting.
    See my previous post for such examples.(The videohelp link is an example for removing Traditional Chinese characters; the one to my blog is a demo video for removing Japanese characters with thick and colored edge.)
    Mar 2011
    Nova Scotia, Canada
    Removing hardcoded subs? That's the dumbest thing I've heard all day.
  11. if hardsubbed, then just download another release, without hardsubs, easiest and the best
