  1. First time post, long time lurker. Hopefully someone here can help me with a little snag I have run into with my latest GNURadio project.
    I would like to take a image in the YUV colorspace, and split the Y, U, and V components to streams to use in an NTSC modulator. I have the RF portion built and from what I can tell, working, but I of course need some valid information to feed into it first.
    The video stream would come from gstreamer, and the output would be named pipes which the individual streams would pass through to the radio.
    My experience in programming is limited to Python at this point. Not sure if that matters here, but figured I'd note that.
    Thanks in advance.
    Last edited by jowijo; 19th Jul 2014 at 16:12. Reason: Used the wrong tense for "built".
  2. Cb, Cr are usually extracted as a greyscale representation of each respective chroma plane, would that work for you?
    There is a ffmpeg gstreamer, and you should be able to use -vf extractplanes to get, Y,Cb,Cr
    http://gstreamer.freedesktop.org/modules/gst-ffmpeg.html
    https://www.ffmpeg.org/ffmpeg-filters.html#extractplanes
    Alternatively, with avisynth you can use greyscale(), utoy(), vtoy() to show the y,u,v planes in greyscale
  3. Originally Posted by poisondeathray View Post
    I'm afraid that isn't quite working. It splits the channels, but it creates video files; I need their values in some raw form.
  4. -c:v rawvideo to decode your source video into raw YUV, the filter -vf extractplanes will split into Y,U,V . You can use ffmpeg to pipe to other applications
  5. If it helps, here is a stupid example of a single pipe of ffmpeg's "u" plane output using stdin to ffplay. "Stupid" because you could just as easily use ffplay with -vf extractplanes directly, but the point is you can pipe ffmpeg to other applications
    "1.avi" source video is 640x360, xvid, YUV 4:2:0 . So that means Y' is 640x360, U is 320x180, V is 320x180
    ffmpeg -i 1.avi -vf extractplanes=u -c:v rawvideo -f rawvideo - | ffplay -f rawvideo -s 320x180 -pix_fmt gray -
    (you don't really need -c:v rawvideo, just -f rawvideo for raw video pipe)
    I'm not familiar with gstreamer, or how to split multiple named pipes in ffmpeg, but it should be possible
