  1. Hi,
    I have Dicataphone SVT or .svt extenstion size of 3 MB,
    I need to convert it to .m t to .mp3
    Thanks in advance.
    Mar 2011
    Nova Scotia, Canada
    Did you ever try s simple web search for something like "convert .svt file"??? I just did. It took 30 seconds.
    However, it yielded absolutely nothing.
    As I suspected, it's a proprietary format used by dictaphone. This is exactly what you'd expect from that sort of company. What that adds up top is: no format spec available = no encoders that understand that format.
    This is exactly the same situation as with pvr file formats. There are a lot of threads here on that subject. They're outta luck and I'm afraid you are too on that count.
    I'd try playing/capturing myself.
  3. may be me can do more if you would post such a svt file
    users currently on my ignore list: deadrats, Stears555
  4. Member Cornucopia's Avatar
    Doesn't the device come with its own editing/transcribing app? Is there no export to wav/mp3 function of any kind?
  5. Member Cornucopia's Avatar
    (Duplicate post)
